cab leveling valve - Printable Version
+--- Forum: Other truck related Help... (/forumdisplay.php?fid=71)
+--- Thread: cab leveling valve (/showthread.php?tid=93)
Pages: 1 2
RE: cab leveling valve - in2trux - 07-20-2016
Is that the cab leveler or suspension leveler?
I should have nothing to to with any vibration at highway speed.
We had a nagging vibration when you let off the throttle at 65. Turns out the valve that the shop installed last year wasn't right. Even though suspension would sit a spec height, they cut the rod 2 inches short and it wasn't enough to keep it where it needed to be going down the road.
Just enough to throw drive angle.
Note to self, always double check any work done. Rides smooth as glass now.
(Tire diameter รท 2) + 8.75" 386 Pete
