| Changing single oil cooler to duel |
| 10-15-2016, (Subject: Changing single oil cooler to duel ) Post: #10 | |||
| RE: Changing single oil cooler to duel Limited owner plan. It's for small, or O/O's. it allows you to register up to 5 S/N's. that's what I did. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
| 10-15-2016, (Subject: Changing single oil cooler to duel ) Post: #11 | |||
| RE: Changing single oil cooler to duel Also I don't know if I need a specific housing for my motor or if they are all the same. I found one on line I thought I would buy it and put new coolers in it and install it but I don't want to waste the money if it doesn't fit. The one's I found they list the casting number? | |||
| 10-16-2016, (Subject: Changing single oil cooler to duel ) Post: #12 | |||
RE: Changing single oil cooler to duel (10-14-2016 )HankAz Wrote: Yup, a little history. I ordered mine as a 600. Last year I put in a recon and didn't have any problems. This summer I started getting red shut down lights at the top of grades. I took it in to Cummins to get it checked out. I had just had issues with the X Y shifter and thought the guy at Kenworth changed something in my parameters. If you are getting shutdown codes for oil problems -- IT IS NOT THE OIL COOLER SINGLE ELEMENT AT FAULT!!! I don't know WHY for the life of me you think that adding a second oil cooler is going to ACTUALLY SOLVE YOUR PROBLEMS!!!! --- FIX THE DAMN PROBLEMS AND STOP TRYING TO MASK THEM!!!!! IF YOU OIL TEMPS ARE TOO HIGH --- * You have a BAD DELETE!? * You have fuel-air mixture problems!? * You have an overheating Turbocharger!? -(what is your BOOST/pyro getting up to in hard pulls ?) * You are ABUSING YOUR ENGINE!? * Static Timing has slipped!? * yOU HAVE A spun bearing!>? * The oil cooler is partially plugged !? -- OR Annodized by BAD (or waterless) ENGINE COOLANT!? * You have a bad oil temp sensor? -- Have you even verified the temps? * Bad oil thermostat?. --=-==== I.E. --- THERE IS AN ACTUAL PROBLEM!!! --- DON'T MASK YOUR PROBLEMS BY MODIFYING YOUR ENGINE!!!--- FIND THE PROBLEM AND FIX IT!!!!!!! User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 10-16-2016, (Subject: Changing single oil cooler to duel ) Post: #13 | |||
| RE: Changing single oil cooler to duel Also I have saw a few cases where it had a bad thermostat. When fully closed it bypasses the oil cooler. Thus purposely heating up oil. Once oil is up to temp it will open. In a few cases it would not fully open and there for bypassing oil cooler partially. | |||
| 10-16-2016, (Subject: Changing single oil cooler to duel ) Post: #14 | |||
| RE: Changing single oil cooler to duel Ah, just figured it out. You can register up to 5 engine Vin. #s for free. Boy you can teach an old dog new tricks. LOL. My CPL is 2919 This recon was ordered in as a 550 then turned up at the dealers when they installed it. I would like to see pictures on QuickServe. All I seem to get are part numbers? Thanks for the help. Hank | |||
| 10-16-2016, (Subject: Changing single oil cooler to duel ) Post: #15 | |||
| RE: Changing single oil cooler to duel Thanks for your help Hammerhead. I was reading these posts on my phone and didn't see the second page. | |||
| 10-16-2016, (Subject: Changing single oil cooler to duel ) Post: #16 | |||
| RE: Changing single oil cooler to duel Curious.... what is the oil temp when the code comes up? My 08 871 in a prostar is a 500 with dual cooler. User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
| 10-16-2016, (Subject: Changing single oil cooler to duel ) Post: #17 | |||
| RE: Changing single oil cooler to duel I think the dealer said it was 240. I know the oil thermostat opens at 235. I did change that and the problem seems to be solved. I'm working on getting gauges to monitor oil temp,pryo and boost but I want to upgrade the cooler anyways when I'm off at Christmas. I'm finding cooler housings and they list the casting number I don't know what will interchange with mine. Anybody?? Thanks for the help Hank | |||
| 10-16-2016, (Subject: Changing single oil cooler to duel ) Post: #18 | |||
| RE: Changing single oil cooler to duel My engine s/n is 79271838 Get them to compare parts lists for you. Or if the parts guys a fucking moron then just go to a local heavy truck salvage yard to compare. User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
