| CM2250 shutting of while trying to take off |
| 10-01-2025, (Subject: CM2250 shutting of while trying to take off ) Post: #10 | |||
RE: CM2250 shutting of while trying to take off (09-23-2025 )Rawze Wrote:(09-23-2025 )tree98 Wrote: Will it pass a leakdown test?....... Just did the test as advices and it passed twice. Only dropped about 400 psi in one minute | |||
| 10-02-2025, (Subject: CM2250 shutting of while trying to take off ) Post: #11 | |||
RE: CM2250 shutting of while trying to take off (10-01-2025 )Rawze Wrote: but will it pass a leak-down test, when done as shown exactly in this video..????> 28722 | |||
| 10-02-2025, (Subject: CM2250 shutting of while trying to take off ) Post: #12 | |||
| RE: CM2250 shutting of while trying to take off when they replaced the fuel pump head, did they replace the tappets, rollers, and plungers too?. .. and did you send over that file for a review as well?. What is your engine ser#?. What make/model vehicle, and maybe some more history on it?. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 10-02-2025, (Subject: CM2250 shutting of while trying to take off ) Post: #13 | |||
RE: CM2250 shutting of while trying to take off (10-02-2025 )Rawze Wrote: when they replaced the fuel pump head, did they replace the tappets, rollers, and plungers too?. Yes they did ESN 79555288 Peterbilt 587 Just was inframed 30 k ago I have had issue with coolant mixing with fuel as well tanks where cleaned but thinking something is plugged up somewhere I will work on downloading the file today.. raining down here in Florida. Yesterday I found the fuel actuator had a lot of play and once I removed it the part that goes into the fuel pump head was bent. I got a new one and once the rain settles I’ll be installing it. Thank you again for your help | |||
