Bought demandated isx, issues tune related?? |
10-06-2025, (Subject: Bought demandated isx, issues tune related?? ) Post: #10 | |||
RE: Bought demandated isx, issues tune related?? (09-28-2025 )BarelyAbleFarms Wrote:(09-28-2025 )Rawze Wrote: ... yup. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
10-06-2025, (Subject: Bought demandated isx, issues tune related?? ) Post: #11 | |||
RE: Bought demandated isx, issues tune related?? (10-05-2025 )Shaman870 Wrote: Try to clean up exhaust pressure sensor line itself: remove that sensor and blow some air where it was. There is a small diameter metal tube that provides pressure data from exhaust, if its clogged, it may affect smoothness of the rpm, depends on de-mandating "style". FYI: The exhaust gas pressure corssover tube itself hardly ever clogs up.. its the passageway thru the thermostat housing, directly below the sensor that almost always does. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
10-06-2025, (Subject: Bought demandated isx, issues tune related?? ) Post: #12 | |||
RE: Bought demandated isx, issues tune related?? whats your location? | |||
Yesterday, (Subject: Bought demandated isx, issues tune related?? ) Post: #13 | |||
RE: Bought demandated isx, issues tune related?? (10-05-2025 )Shaman870 Wrote: Try to clean up exhaust pressure sensor line itself: remove that sensor and blow some air where it was. There is a small diameter metal tube that provides pressure data from exhaust, if its clogged, it may affect smoothness of the rpm, depends on de-mandating "style". I appreciate the tip. I did blow air down the hole where the sensor goes, when I was installing the new sensor. I was getting the short to ground code and that's why I went ahead and replaced the sensor. Air seemed to flow thru without much restriction. | |||
Yesterday, (Subject: Bought demandated isx, issues tune related?? ) Post: #14 | |||
RE: Bought demandated isx, issues tune related?? | |||
