Havig a bad day. CM2350 fuel pump failure. |
07-07-2017, (Subject: Havig a bad day. CM2350 fuel pump failure. ) Post: #10 | |||
RE: Havig a bad day. CM2350 fuel pump failure. Is it possible to catch and filter the oil coming from the fuel pump before returning to the engine. | |||
07-07-2017, (Subject: Havig a bad day. CM2350 fuel pump failure. ) Post: #11 | |||
RE: Havig a bad day. CM2350 fuel pump failure. (07-07-2017 )arch_stanton Wrote: Is it possible to catch and filter the oil coming from the fuel pump before returning to the engine. i don;t think so but this comes to mind... http://enginecare.com.au/wp-content/uplo...Switch.pdf User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
07-07-2017, (Subject: Havig a bad day. CM2350 fuel pump failure. ) Post: #12 | |||
RE: Havig a bad day. CM2350 fuel pump failure. well that looks like a great solution | |||
07-07-2017, (Subject: Havig a bad day. CM2350 fuel pump failure. ) Post: #13 | |||
RE: Havig a bad day. CM2350 fuel pump failure. Another thing to consider is the micron rating on the filters. I was at a parts house getting fuel and oil filters. Because he actually carries the right oil filter the dealer does not and argues with you about it. Any how I ask what the micron rating was for these fuel filters he told me it was 4 micron. He didn't carrie that one so I had him order the right one. Makes me wonder how many of these trucks are running around with the wrong filters on them. Like a 10 micron or so. I told the dealer no wonder these engines have cam failures with you guys always putting on the wrong filters. Kinda funny watching there reaction. The dealers sell the cheapest filters they can get away with. Ever trucker says I want filters. If there too much money I'll get them somewhere else. So you get the $40 dollar filter instead of the $60 dollar filter that it really should have. | |||
07-07-2017, (Subject: Havig a bad day. CM2350 fuel pump failure. ) Post: #14 | |||
RE: Havig a bad day. CM2350 fuel pump failure. Would a strong magnet in the oil pan also catch the metal debris and save a motor | |||
07-10-2017, (Subject: Havig a bad day. CM2350 fuel pump failure. ) Post: #15 | |||
RE: Havig a bad day. CM2350 fuel pump failure. (07-07-2017 )Rawze Wrote: As a follow-up to this...could something like this coolant flush tool be use to flush the engine but with the oil/diesel mix https://youtu.be/n6TVKwiINQ4 | |||
08-23-2017, (Subject: Havig a bad day. CM2350 fuel pump failure. ) Post: #16 | |||
RE: Havig a bad day. CM2350 fuel pump failure. Thanks for this post. I am dealing with this very issue as we speak. CRAP! | |||
08-23-2017, (Subject: Havig a bad day. CM2350 fuel pump failure. ) Post: #17 | |||
RE: Havig a bad day. CM2350 fuel pump failure. I have a filter mag on my oil filter. got it from Pittsburgh power. they have them for oil@ fuel | |||
08-23-2017, (Subject: Havig a bad day. CM2350 fuel pump failure. ) Post: #18 | |||
RE: Havig a bad day. CM2350 fuel pump failure. You can also get them through summit. That's where I got mine. User's Signature: 2010 T2000, CM871, 13spd, 1.173m, tanker yanker Overhauled @ 927k | |||
