Removing Rust the awesome way
03-17-2016, (Subject: Removing Rust the awesome way )
RE: Removing Rust the awesome way
(03-17-2016 )snailexpress Wrote:
(03-16-2016 )RPM1 Wrote:
will it work on Galvanised steel ?
It will work on everything but will eat zinc more aggressive then rust.
https://www.youtube.com/watch?v=TvlllG1FwjI
You can buy same as muriatic acid 33% from HD or lowes cheaper and dilute with water 50/50 to same concentration.
It will make it 4 time cheaper.
[/quote]
Actually, the stuff is a lot more than simple muriatic acid. It has several other ingredients than just hydrochloric acid. Seemed to be more potent with less acid content.
