Proper engine warm up procedure?
01-17-2018, (Subject: Proper engine warm up procedure? )
RE: Proper engine warm up procedure?
(01-17-2018 )jimeneztrans84 Wrote:  What are you guys setting your idle rpm at? Mine is at 600 rpm. Cm2250
Set mine to 700.......can adjust at anytime.
User's Signature: You want how much?
 Thanks given by: hhow55 , Rawze
I like to see them at least 700 - 800 rpm. this is to keep oil pressure up.
I am 650 low idle, and 850 high.
01-18-2018, (Subject: Proper engine warm up procedure? )
I leave mine set pretty low , but I don't leave it idle at all expect for at lights type thing . I always bump mine up to 900 or 1000 , it doesn't hunt for rpm at 1000 as bad and will stay a lot warmer in our tropical climate .
The reason for my idle set at 600 is for " lifting super bs " I believe it's a lot easier on the clutch . I am probably way out to lunch , but that's my program ...
Oh and yes I know I need to fix it , a year and a half I put 3600 into it and never fixed it . This breakup she is probably getting 3 new injectors
