|     Exhaust Gascket leaks    |
|    03-25-2018, (Subject: Exhaust Gascket leaks )   Post: #10   |  |||
 RE: Exhaust Gascket leaks  (03-25-2018 )alborz Wrote: the gasket for that cylinder was bad. both my new problem is that the exhaust manifold bolt for the fifth cylinder broke inside. the lower bolt. I tried to use bolt extractor. the extractor broke inside too. and you know the extractor is hardened steel and can't drill through it. anyone has had this problem and solved successfully? I have done this, and I have fixed it for a few others that have as well. It's painfully slow, but it can be done. I have a rotary tool with a long flexi shaft leading to a nice small handle that is controlled via a foot pedal, think dentists type of thing...you can also use a dremel tool. Get a good quality, small round tipped carbide burr. Take your time, it's NOT gonna happen fast. Your using something extremely hard to grind something very hard, so patience is the key. Good luck, and next time you won't be so ham fisted, because you'll know how much of a PITA extracting the broken piece will be if you don't. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..."  |  |||
|    03-25-2018, (Subject: Exhaust Gascket leaks )   Post: #11   |  |||
|  RE: Exhaust Gascket leaks    What I have found works for removing broken studs is building them up with weld. Build them up until you can either weld a nut on or turn them out with a vice grip. The best rod I found is Arctec Unicrom 265 1/16 or 3/32. If you need more info PM me.     |  |||
|    03-25-2018, (Subject: Exhaust Gascket leaks )   Post: #12   |  |||
 RE: Exhaust Gascket leaks  (03-25-2018 )MCRENT Wrote:(03-25-2018 )alborz Wrote: the gasket for that cylinder was bad. both my new problem is that the exhaust manifold bolt for the fifth cylinder broke inside. the lower bolt. I tried to use bolt extractor. the extractor broke inside too. and you know the extractor is hardened steel and can't drill through it. anyone has had this problem and solved successfully? it does not work with that. I tried to use Dremel to just grind it out but Dremel bits are so fragile and break fast  |  |||
|    03-26-2018, (Subject: Exhaust Gascket leaks )   Post: #13   |  |||
|  RE: Exhaust Gascket leaks    You need to find an actual good quality carbide burr that will fit your dremel tool, not a bit that comes with a dremel tool.  I get mine from a machine shop supply place at home. They're about $40/ for the good ones... User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..."  |  |||
|    03-26-2018, (Subject: Exhaust Gascket leaks )   Post: #14   |  |||
 RE: Exhaust Gascket leaks  (03-26-2018 )Hammerhead Wrote: You need to find an actual good quality carbide burr that will fit your dremel tool, not a bit that comes with a dremel tool. Thank you for your comments Can you send me picture of it with its name?  |  |||
