| Coolant coming out reservoir and WP leak |
| 05-09-2018, (Subject: Coolant coming out reservoir and WP leak ) Post: #10 | |||
RE: Coolant coming out reservoir and WP leak (05-07-2018 )Brock Wrote: That's because you used a rad cap but did you block the pressure relief cap? Sounds to me like the pressure relief cap was doing it's job and relieving the pressure at 12psi. I did run a hose from overflow into a bottle of water when the engine was warm and ran it up to 1400 rpm. No bubbles...thats why I was considering all possibilities. If it turns out to be a head gasket...its probably full rebuild time. Then I'll talk to unilever about my options. | |||
