White Exhaust Stack |
10-02-2018, (Subject: White Exhaust Stack ) Post: #10 | |||
RE: White Exhaust Stack (10-02-2018 )Rounded_nut Wrote: And don't forget to get enough oring washers, Cummins is against including everything you'll need in a handy kit. Done yourself, should be able to eat breakfast and get to work, wrap it up before you're hungry for dinner(lunch). I just was working on the books and came across my parts, I also did my fuel pump actuator and for parts only it was around the 600-700 dollar mark. And don't tip the rollers sideways or the pin slides out..... What was the reasoning for doing the fuel pump actuator?? | |||
10-03-2018, (Subject: White Exhaust Stack ) Post: #11 | |||
RE: White Exhaust Stack Irrelivant post | |||
10-03-2018, (Subject: White Exhaust Stack ) Post: #12 | |||
RE: White Exhaust Stack Here are the fuel pump parts numbers for the ISX15 2250 and 2350. They ARE NOT compatible with each other. link: http://rawze.com/forums/showthread.php?t...5#pid14615 | |||
