| Screaming truck |
| 09-23-2019, (Subject: Screaming truck ) Post: #10 | |||
| RE: Screaming truck Mine was on the intake side, under the piping,or are you asking for mine lol | |||
| 09-23-2019, (Subject: Screaming truck ) Post: #11 | |||
| RE: Screaming truck No, I was just curious if it was there in general, so I can look for it User's Signature: I have no idea what I’m doing and probably need supervising | |||
| 09-24-2019, (Subject: Screaming truck ) Post: #12 | |||
| RE: Screaming truck On my 871, I have the larger turbo, 5xx series I believe, the part number was on a plate tacked to the side of the turbo housing. I don't recall any physical stamping on the turbo itself, but that does not mean there is not one. You can look up your turbo on Cummins Quickserve, just type in your engine serial number, it should give you the correct part number for the turbo and actuator for your particular motor. | |||
| 09-24-2019, (Subject: Screaming truck ) Post: #13 | |||
RE: Screaming truck (09-23-2019 )DDlighttruck Wrote: Is the part number for the turbo stamped on it anywhere? There will be a rectangular Holset tag on the compressor housing for the turbo as an assembly if it's survived over the years. If there is any other numbers stamped it will be for individual parts or sub assemblies. | |||
| 09-24-2019, (Subject: Screaming truck ) Post: #14 | |||
| RE: Screaming truck I would definitely check your CAC out while it's down as that chewed up debris went somewhere. | |||
| 10-14-2019, (Subject: Screaming truck ) Post: #15 | |||
| RE: Screaming truck I'm also having that howling/screaming issue, and I'll be checking my turbo as soon as I get home. Its louder on steep pulls. | |||
| 10-14-2019, (Subject: Screaming truck ) Post: #16 | |||
| RE: Screaming truck Just adding this here for reference. Maybe will help others who are having similar issues but did not find any metal shavings or damage upon inspection. (01-16-2018 )Rawze Wrote: ... Part of this original post: http://rawze.com/forums/showthread.php?t...7#pid22387 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
