Noisy air compressor |
01-10-2020, (Subject: Noisy air compressor ) Post: #10 | |||
RE: Noisy air compressor (01-10-2020 )Waterloo Wrote:So, I got in last night and messed with the compressor. I put some room temperature water in a spray bottle. I took the inlet from the manifold, pumped the air down to 80lbs. While it was pumping air I sprayed water in the inlet. Its warm here in NC and I didn't use a lot of water. I didn't want to use oil because it would collect dust more. After I put it back together I kept pumping the air down and letting it build and spit off. My dryer works really good, hasn't been long since I replaced the spitter, govenor and filter. I drove it today to load a load for Monday and it sounded really good, no more rattle.(01-09-2020 )tree98 Wrote: Good quality remans!! | |||
01-11-2020, (Subject: Noisy air compressor ) Post: #11 | |||
RE: Noisy air compressor (01-10-2020 )Ricky Wrote:(01-10-2020 )Waterloo Wrote:So, I got in last night and messed with the compressor. I put some room temperature water in a spray bottle. I took the inlet from the manifold, pumped the air down to 80lbs. While it was pumping air I sprayed water in the inlet. Its warm here in NC and I didn't use a lot of water. I didn't want to use oil because it would collect dust more. After I put it back together I kept pumping the air down and letting it build and spit off. My dryer works really good, hasn't been long since I replaced the spitter, govenor and filter. I drove it today to load a load for Monday and it sounded really good, no more rattle.(01-09-2020 )tree98 Wrote: Good quality remans!! there used to be a procedure on quickserv where you disconnect inlet and outlet lines form the compressor and spray it with wd-40 to clean out the head and unloader valve assy. etc. from carbon. Your also supposed to inspect the lines from the compressor to the air dryer for carbon buildup as well, to see how bad the air system has gotten?. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
