Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability |
08-07-2020, (Subject: Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability ) Post: #10 | |||
RE: Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability (08-07-2020 )redbeard Wrote: Do your Homework, don’t buy a MX13. And thank u also and so as long as I maintain the isx Cummins every month or 1 or 2 months and change everything and keep it running good u say that the isx isn’t that bad that that usually happens to ppl that don’t maintain the engine? I’m just here for to do the homework cuz can’t find it anywere else if I have to have a horriable engine on hills if it’s reliable I’d still go reliable I just want to know wats the better choice thanks again | |||
08-07-2020, (Subject: Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability ) Post: #11 | |||
RE: Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability Also I’d be an idiot if you didn’t buy the extended warranty on these engines if it was a 1990s cat or Detroit I’d be fine but u need to cover all the crap the put on these new ones from wat I hear and know with emissions | |||
08-08-2020, (Subject: Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability ) Post: #12 | |||
RE: Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability rofl ok...well see how much that warranty costs you in downtime vs buying the part and fixing it yourself. plus dealers cant fix a headlight right and you want to trust em with your engine. User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
08-08-2020, (Subject: Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability ) Post: #13 | |||
RE: Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability (08-07-2020 )Cummins5555 Wrote: Also I’d be an idiot if you didn’t buy the extended warranty on these engines if it was a 1990s cat or Detroit I’d be fine but u need to cover all the crap the put on these new ones from wat I hear and know with emissions An extended warranty is a waste of money. Not talking down to you, just telling you the truth. Have you ever even owned a truck before? If you take care of a truck, learn how it works, especially these emission motors and invest that warranty money into tools and diagnostic equipment, and you should have plenty left over for a trip to the islands if you stick to the basic tools, you will never need a warranty. Most of the repairs on these trucks are simple maintenance, there is that word again, sensor replacements, servicing and not driving the truck like a dummy, like lugging the motor or abusing it in other ways. You need some tools, the diagnostics, which Cummins gives you those for free, and the ability to get your hands dirty and do the work yourself. Only you will care enough to do the job properly, a dealer could care less, plenty of stories here to back up that comment. User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
08-08-2020, (Subject: Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability ) Post: #14 | |||
RE: Need help please 2014 to 2016 Mx 13 vs Cummins isx reliability The answer to your question is....... buy the Cummins. There you go. User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
