axles with tapered retainers that are hard to remove.... |
08-12-2020, (Subject: axles with tapered retainers that are hard to remove.... ) Post: #10 | |||
RE: axles with tapered retainers that are hard to remove.... I love when rawze works on Volvo’s User's Signature: The creator said " Help your self and I will help you; Protect your self and I will protect you " | |||
01-27-2021, (Subject: axles with tapered retainers that are hard to remove.... ) Post: #11 | |||
RE: axles with tapered retainers that are hard to remove.... We have lots of luck after a couple of swats with the heaviest sledge you have take a small chisel, thinned down and drive it in the split on the wedge then with a pair of channel locks grab the cooler and rotate and twist at the same time. Some good penetrant and your away. | |||
