| Anyone get code 1911 for cm2250? |
| 07-21-2016, (Subject: Anyone get code 1911 for cm2250? ) Post: #10 | |||
| RE: Anyone get code 1911 for cm2250? Hi jt84, good to see u are getting closer to fix ur engine problems Can't comment on any of it , I have the '14 2350 so I'm following u closely cause I may end up having the same on mine..... I do wanna ask u or anyone else that own 22/2350's if they monitor their fuel filter and water separator cartridge for steel/copper shavings???? Very small particles did start showing on my both filters when I change them and/or drop all fuel and debris gathered on the bottom of the w separator Btwy how much was the fuel relief pressure valve, and how hard is to change it??? Tnx | |||
| 07-21-2016, (Subject: Anyone get code 1911 for cm2250? ) Post: #11 | |||
| RE: Anyone get code 1911 for cm2250? Are you getting any codes for a fuel rail pressure? Or a code for intermittent power loss?? Make sure your fuses are tight on the fuse block on d/s | |||
| 07-21-2016, (Subject: Anyone get code 1911 for cm2250? ) Post: #12 | |||
| RE: Anyone get code 1911 for cm2250? Hey t680, I wouldn't know much about finding particles on your fuel filters. But I'm sure that can't be good..someone else might comment on it. I think on the 2350 alot of the problems were fixed. It's the 2011-12 cm2250 that came out with alot of problems. Just keep up with maintenance and try to catch problems before they get worse. Fuel pressure valve cost $300 and I installed it in like 30 min. Gonna take my truck today to measure fuel pressures and get to the bottom of this code 1911 | |||
| 07-21-2016, (Subject: Anyone get code 1911 for cm2250? ) Post: #13 | |||
| RE: Anyone get code 1911 for cm2250? Still code 1911 fuel rail pressure | |||
| 07-21-2016, (Subject: Anyone get code 1911 for cm2250? ) Post: #14 | |||
| RE: Anyone get code 1911 for cm2250? Restriction/leak in the line keeping it from getting full flow? Something just occurred to me, could the fuel pressure sensor be faulty? | |||
| 07-21-2016, (Subject: Anyone get code 1911 for cm2250? ) Post: #15 | |||
| RE: Anyone get code 1911 for cm2250? There's too much fuel shooting. The only thing that can cause that is fuel pump actuator no? | |||
| 07-21-2016, (Subject: Anyone get code 1911 for cm2250? ) Post: #16 | |||
| RE: Anyone get code 1911 for cm2250? air in the fuel pump failing bad actuator bad relief bad cal bad filters fuel inlet restriction bad pressure sensor a sudden spike in voltage these are the main things for a 1911, most of the time its the air or actuator failing. | |||
| 07-21-2016, (Subject: Anyone get code 1911 for cm2250? ) Post: #17 | |||
| RE: Anyone get code 1911 for cm2250? Replaced filters, relief valve (got power back after swapping) replaced pressure sensor a couple months back but still have a spare one/ I'll swap it out. Pump I just swapped out also but was used one / it did the same thing with 3 cylinder pump too though only 1 time, more with 2 cylinder pump. | |||
| 07-21-2016, (Subject: Anyone get code 1911 for cm2250? ) Post: #18 | |||
RE: Anyone get code 1911 for cm2250? (07-21-2016 )jimeneztrans84 Wrote: ... There is a protection in the ECM for overpressure/sudden fuel temp change that will make truck feel like you let go of the throttle for a split second, than back. If you are pressing hard on the throttle and the truck/fuel is not fully warmed up yet, this protection will kick in to prevent over-pressure of the rail. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
