| Aftertreatment Temperature Stabilization |
| 10-03-2020, (Subject: Aftertreatment Temperature Stabilization ) Post: #10 | |||
| RE: Aftertreatment Temperature Stabilization Another thing I have thought about... easier said than done though. Here I sit in a Farmhouse that my great-grandparents bought in 1942. I bought it 11 years ago and am about 90% through restoring it. I have been in business for myself here for 19 years and have built up a pretty good local customer base. Hard to uproot. Maybe I can get Trump to hold off on Mexico wall construction and build a wall between NYC and the rest of the state. Get us separated so the rest of us up here in the red counties don’t have to get lumped in with the “blue state” politics. | |||
| 10-03-2020, (Subject: Aftertreatment Temperature Stabilization ) Post: #11 | |||
RE: Aftertreatment Temperature Stabilization (10-03-2020 )ahub86 Wrote: ... Just an update... It is called the "Stay Warm" feature in the programming. it is part of the 'Soot Filter Reduction' manager and the 'Emissions auXiliary reduction Manager' systems in the ecm. It essentially will extend the regen cycle and keep it active at low speeds for up to 10 minutes (then it times out) if it is in a regen and you slow down. I would imagine this would consume more fuel, dumping it into the exhaust to keep the system hot while it is in this state. Guess it would be a trade-off of possibly more complete regen cycle on trucks that stop/go a lot at the expense of some extra fuel ... for up to 10 minutes before cancelling the regen cycle. -- just speculation based on what I have seen of it behind the scenes in the ecm programming. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 10-04-2020, (Subject: Aftertreatment Temperature Stabilization ) Post: #12 | |||
RE: Aftertreatment Temperature Stabilization (10-03-2020 )ahub86 Wrote: It’s ok if you don’t have a divisible load permit. If your truck complies with federal bridge law you are ok. But for example my tri axle dump truck would register gross at 58,000 lbs under bridge law. With the divisible load permit I am 73,750 lbs. Get caught with non steerable and they pull your permit for an extended period and it’s hard to get back. Get caught non steerable with 73,750 gross and then only good for 58,000. Stuck with an almost 8 ton overload ticket. I just woke up, still have not had my first coffee... I have a ProStar with a steerable 8,000 lb lift axle in front of my 40,000 lb drive axles to assist in getting the weight off of my 12,000 lb steer axle. I never haul over 80,000 gross, do not require any permits to pull my 53' dry van. If by chance I go to NY, am I going to have any issues with the DOT up there? From what I am comprehending in my currently foggy mind, is that I am ok if I do not require permits? Thank you. And NY sucks. User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
| 10-04-2020, (Subject: Aftertreatment Temperature Stabilization ) Post: #13 | |||
| RE: Aftertreatment Temperature Stabilization Ok thank you. I had a basic theory myself of how this was going to work. Sounds like what it’s thinking coincided with what your telling me. I just couldn’t find any specifics about it when I searched anywhere. Like the 10 minute time limit. Maybe what I need to do is put the truck in service and just see show it goes with it off. Watching fuel mileage and regen history etc. for about half my busy season. Then enable it for the rest and compare. Maybe I can produce some real world data for the dump trucks out there. | |||
| 10-04-2020, (Subject: Aftertreatment Temperature Stabilization ) Post: #14 | |||
| RE: Aftertreatment Temperature Stabilization I run dumpsters, before I had mine ‘fixed’, that feature was helpful,lots of stop and go and pro time, but it made about a -.5mpg difference when a regen ran. That adds up quick. | |||
| 10-10-2020, (Subject: Aftertreatment Temperature Stabilization ) Post: #15 | |||
RE: Aftertreatment Temperature Stabilization (10-03-2020 )Rawze Wrote: Just an update... It is called the "Stay Warm" feature in the programming. it is part of the 'Soot Filter Reduction' manager and the 'Emissions auXiliary reduction Manager' systems in the ecm. It essentially will extend the regen cycle and keep it active at low speeds for up to 10 minutes (then it times out) if it is in a regen and you slow down. The "Stay Warm" has been helpful on school buses w/ 2350 ISB 6.7. Does Cummins have a Regen Inhibit option? The medium NAV MF engines I work with can have that option enabled. Very helpful in stop and go operations, in city, landscape dumps, short haul etc. Works well IF the drivers are not idiots. Big IF. Stops the engine from doing active regen on it's own. Used by a non idiot the truck is operated until the 1st stage DPF warning comes on. Operation can continue for a while. Then when the truck can be out of service for 30 to 50 minutes a parked regen can be run. This strategy lets a complete regen run. This works well depending on the driver. What was happening before was the ECM commanded regens usually never got to complete. Truck would be stopped, or go under 7mph all of which stop the regen. Since the DPF didn't get fully "emptied" they would regen a lot. Since many of these use in cylinder dosing that would lead to fuel dilution and other problems.. Have not seen this option in INSITE on the ones I have looked at. BTW may have a good "EGR tuneup" success story in a few days. Waiting on results. | |||
| 03-29-2024, (Subject: Aftertreatment Temperature Stabilization ) Post: #16 | |||
| RE: Aftertreatment Temperature Stabilization I have a 2019 X15 in a KW dump truck that has "Stay warm" feature enabled and I believe by description of operation is causing an issue. This truck will kick up the idle from 600 rpm to 800 rpm and spool up the turbo and engine state goes to "active regen" yet no temps raise. It will do this every time you drive the truck over 5mph and will "kick in" and stay for 4-5 minutes then idle back down and spool down the turbo. No codes and no reason I can see for this to keep doing this. Even when truck is cold or just after a completed regen, drive the truck over 5 mph and kicks up. Truck has lasted calibration, but If I recalibrate it with latest it will stop doing it for about 4-5 hours then starts up again with no codes or anything I can see out of wack... New DPF and cleaned SCR/DOC. I tried to disable this feature but even with zap-it cant get it unlocked. | |||
| 03-29-2024, (Subject: Aftertreatment Temperature Stabilization ) Post: #17 | |||
RE: Aftertreatment Temperature Stabilization (03-29-2024 )Innocent Bystander Wrote: I have a 2019 X15 in a KW dump truck that has "Stay warm" feature enabled and I believe by description of operation is causing an issue. This truck will kick up the idle from 600 rpm to 800 rpm and spool up the turbo and engine state goes to "active regen" yet no temps raise. It will do this every time you drive the truck over 5mph and will "kick in" and stay for 4-5 minutes then idle back down and spool down the turbo. No codes and no reason I can see for this to keep doing this. Even when truck is cold or just after a completed regen, drive the truck over 5 mph and kicks up. Truck has lasted calibration, but If I recalibrate it with latest it will stop doing it for about 4-5 hours then starts up again with no codes or anything I can see out of wack... New DPF and cleaned SCR/DOC. I tried to disable this feature but even with zap-it cant get it unlocked. sounds pretty normal to me. It has to keep that DPF, etc.. at around 500-F or so at all times for it to operate properly .. and it sounds like its simply changing operating modes to keep it there, like its supposed to whenever it gets cooled off too much for various reasons. it being a dump truck with a lot of stop and go and idle ... doing an exhaust wrap on the pipes and system would trap that heat in and stabilize it more. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
