| Shocks |
| 08-23-2016, (Subject: Shocks ) Post: #10 | |||
RE: Shocks (08-23-2016 )axe Wrote:(08-23-2016 )74bassman Wrote: Where did you get the monroe shocs?? Do you have a part number?? You could order them online Im sure also, probably cheaper if you don't have a good contact. My father owned NAPA store for over 40 years so I get pretty good discount. | |||
| 08-23-2016, (Subject: Shocks ) Post: #11 | |||
RE: Shocks (08-23-2016 )axe Wrote:(08-23-2016 )axe Wrote:(08-23-2016 )74bassman Wrote: Where did you get the monroe shocs?? Do you have a part number?? What kind of truck do you have? I thought in some of your posts I read were you had a Volvo. I have a Prostar but have had couple of Volvos in the past. Volvos are hard on front suspension, as someone else said put a good gas charged shock on there. Post year make and model of truck, gurus will be active ina while, they will guide ya. | |||
| 08-23-2016, (Subject: Shocks ) Post: #12 | |||
| RE: Shocks Hopefully, spent over a hour at peterbuilt on the phone with rush trying to get part numbers. Rush kept me on hold, and peterbuilt couldn't cross reference any numbers. I now need to replace the transmission mounts also. Mr Hagg what would be the turn around if I brought you the truck in the am, to replace transmission mounts, shocks, and damper | |||
| 08-23-2016, (Subject: Shocks ) Post: #13 | |||
| RE: Shocks 74bassman We are pretty backed up our selves. With one inframe and one getting a list a mile long. We might be able to work something in Friday but that would be the soonest. However as far as front end work I can call Hiil Tire in the morning and see what they can do. I also Have another shop we use for alignment here locally I can call if you want me to. | |||
| 08-23-2016, (Subject: Shocks ) Post: #14 | |||
| RE: Shocks Ok thanks, let me know. | |||
| 08-23-2016, (Subject: Shocks ) Post: #15 | |||
| RE: Shocks Prostar steers shocks Gabriels part#85954 Drives part#85931 Those are the cross numbers from the originals hopefully that helps so far on my prostar are holding real good. | |||
| 08-24-2016, (Subject: Shocks ) Post: #16 | |||
| RE: Shocks I have 2010 prostar. | |||
| 08-24-2016, (Subject: Shocks ) Post: #17 | |||
| RE: Shocks Tried napa this AM, they said those part numbers are obsolete. | |||
| 08-24-2016, (Subject: Shocks ) Post: #18 | |||
| RE: Shocks | |||
