2006 379 Pete w/cm870 ISX. |
10-18-2023, (Subject: 2006 379 Pete w/cm870 ISX. ) Post: #10 | |||
RE: 2006 379 Pete w/cm870 ISX. Rawze sir All my other sensors are working properly that are currently being utilized except the egr valve and now the egr temp. What was driving me crazy is the ecm shows pid 9 as amb tem sensor input pid at ecm but can’t find out where it goes. At the vary least now I know what electrical tree branch if it were to look on. Seems all the temp sensors are in series on the same electrical line. User's Signature: Have you checked your muffler bearings today? | |||
08-14-2024, (Subject: 2006 379 Pete w/cm870 ISX. ) Post: #11 | |||
RE: 2006 379 Pete w/cm870 ISX. My 06 cm870 value always sits at 72. Doesn’t say calculated but I think it doesn’t use it as a reading at all User's Signature: I may be cross eyed, but i don’t cross thread | |||
08-14-2024, (Subject: 2006 379 Pete w/cm870 ISX. ) Post: #12 | |||
RE: 2006 379 Pete w/cm870 ISX. registering your engine ser# on quickserv.com (free) will let you get to the ecm wiring diagrams for it. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
