|  Insite issue, fault will not clear ...  |
|  03-14-2024, (Subject: Insite issue, fault will not clear ... )  Post: #10 | |||
| RE: Insite issue, fault will not clear ...  [quote='DVT873' pid='80276' dateline='1710385832'] If it is the type where the sensor tip is in the coolant sometimes they get a buildup of crud on them that insulates it from the coolant. Sandpaper the crud off and most times they will start working. yes my uncle told me that trick today as well. thanks | |||
|  05-09-2024, (Subject: Insite issue, fault will not clear ... )  Post: #11 | |||
| RE: Insite issue, fault will not clear ... (03-13-2024 )DVT873 Wrote: If it is the type where the sensor tip is in the coolant sometimes they get a buildup of crud on them that insulates it from the coolant. Sandpaper the crud off and most times they will start working. I have had this issue too i went round and round checking wiring and other things then ended up changing the sensor because it looked like it had rust on it and it took care of the issue | |||
