ISB 6.7 CM2150 problem
05-01-2024, (Subject: ISB 6.7 CM2150 problem )
RE: ISB 6.7 CM2150 problem
(04-30-2024 )Notch Wrote:  I've had a customer's 6.7 in a RAM pickup that they suspected an employee had filled the diesel tank with gasoline. The truck ran poorly, would hardly rev, had some audible knocking/detonation noises when running, and had a ton of grey smoke from the exhaust. The big red flag for what was causing the issue was when the fuel filter cap on the engine was removed you were overwhelmed by the smell of gasoline. Surprisingly enough, a fresh tank of diesel and 2 new fuel filters and the truck ran fine and they drove it away.
GOOD INFO...
but now it also points towards ... if it is de-mandated, .. it will also 100% be likely to have a bad, engine killing de-mandate program in it too.
04-02-2025, (Subject: ISB 6.7 CM2150 problem )
So I was looking at this again with Insite. Everything is still the same with the following observations:
RPM's will not go above 1100, engine sputters and stumbles, but will go back to idling great. Grey smoke mostly on acceleration.
Intake manifold pressure still at 0.0inHg 0.63v. Does not change
Fuel rail pressure will not go above 19k, except it goes to 24k on leakage test
Fuel pump actuator - position Closed. Current stays 1375mA drops to 1250mA upon acceleration
Turbo Commanded equals Measured - 31% to 65%max
Turbo Actuator Position Sensor Voltage always 0v
Turbo Compressor IAT sensor stays at 2.13v only
Turbo rpm up to 19k down to 6594 steady
Engine oil pressure 0v but gauge works
No boost (you can hold your hand over the outlet and it will not push your hand away)
I have done the following:
Changed turbo actuator, realigned gear, and calibrated with Insite
Disassembled turbo, cleaned everything thoroughly, and made sure vane ring and lever moves freely. Compressor spins great
Drained fuel and installed new filters
New IAT
Demandated everything and properly tuned
Insite tests:
Cutout test fine. All cylinders will reduce RPM approx 50rpm upon cutout
Cylinder performance test all pass
EFC Actuator override test - position open
Am I missing something or do I just need to throw some money at it with a new turbo? Thx!
You say this is is a RAM truck? How did you calibrate the turbo actuator with insite? The RAM's that I've been able to connect to with insite still would not allow me to calibrate the turbo actuator. They also showed data that wasn't always accurate. Some of the values you listed might not be correct because insite doesn't process the data properly on RAM cummins. What year is this truck?
Actually, it is a 2011 Freightliner M2
How much of the turbo did you take apart when you cleaned it? The shaft has to be high speed balanced with special equipment. If its not balanced and maybe not turning as free as it should that could be your problem.
I didn't remove the shaft or compressor wheels. I used brake cleaner and compressed air to clean under and around those. Mostly I worked on the vanes and the gears until it moved freely, and cleaned the soot out of the housings
04-03-2025, (Subject: ISB 6.7 CM2150 problem )
Have you replaced the exhaust pressure sensor and made sure the entire circuit for it is clean and not blocked with carbon?
(04-02-2025 )Stovedude Wrote:  ...
I guess my earlier post was ignored?...
Copy the program from the ecm and e-mail it to me for e review of what someone did in there.
Thanks Rawze. I thought I had it on my laptop, but it must have been removed. I will get it this weekend
