2012 Isx 15 rattle noise top driver side |
03-01-2016, (Subject: 2012 Isx 15 rattle noise top driver side ) Post: #10 | |||
RE: 2012 Isx 15 rattle noise top driver side (02-29-2016 )Broncof15079 Wrote: I have a 2012 T700 with cummins Isx15 450hp 488,000miles, 1 month ago it started to rattle. No engine codes When the truck starts to pull a grade it will start a rattle really loud it sounds like its on top of engine, and only around 1400 to 1600rpm , if I let off on pedal it goes away, when I get back on the pedal rattle comes back ( sound is like bearings or valves coming apart). So far mechanic done dpf and doc filter clean and burn, overhead adjustment and has not been able to solve problem.. I have exact same truck and mine did the same thing. It's the hood rattling. I had to shim the hood latch on the driver's side to make it tighter and the rattle went away. | |||
03-03-2016, (Subject: 2012 Isx 15 rattle noise top driver side ) Post: #11 | |||
RE: 2012 Isx 15 rattle noise top driver side Found the problem, it ended up being a clucht bearing, under power it would rattle up the clucht pedal. | |||
03-03-2016, (Subject: 2012 Isx 15 rattle noise top driver side ) Post: #12 | |||
RE: 2012 Isx 15 rattle noise top driver side Special thanks to Hedley! | |||
