2024 x15 ticking at 1400 rpm
03-05-2025, (Subject: 2024 x15 ticking at 1400 rpm )
RE: 2024 x15 ticking at 1400 rpm
Ok so I got the scanner played with it a bit and did the leak down test didn't seem to affect much however the truck wasn't actin up at the time either. Did the test twice once showed 28910 next showed max press at 29100.
There was the normal ticking from the injection pump but this fuel knock or something is different seems very one injector kinda noise.
It could be an injector, do a cylinder cut out test.
I would also say to inspect the overhead cam too for lobe wear/damage + do an overhead cam adjustment while your in there too.
I agree with rawze. A lot of the ticking complaints we've seen have been the cam lobes starting to go.
I sure hope a brand new truck with only 3k km on it doesn't have cam wear.
(03-05-2025 )tree98 Wrote:  I sure hope a brand new truck with only 3k km on it doesn't have cam wear.
You busted me not reading page one of the post.
 Thanks given by: tree98
Ok, so the fuel pressure is good @
>30000, im struggling with quickserv and how to get the proper specs. I noticed the noise at 3 or under 3ks it now has 12ks but 450 engine hours. I will try the cutout test tomorrow but it would it only be effective if I can verify the noise is happening at that time I do the test. It isn't coming and going necessarily just not as pronounced. I hear it so much its almost becoming normal.... and then it starts tacking away and I think, wow that is a shi#t noise. Do I need to do any more tests before opening up the the top end, any special tools. I would love a way to verify a cylinder, specifically, with a stethoscope beforehand so I can confirm an issue or at least make it easier to verify.
I'll bet you find it right away with a cut out test.
03-14-2025, (Subject: 2024 x15 ticking at 1400 rpm )
Hey I have not had a chance to do the test I will soon but I did upload this clip to YouTube https://youtube.com/shorts/t8JX12FAoek?s...ERXB66-kBe . Give it a listen let me know what you think The engine was at 1100 PTo on, had just finished Regen.
