| Here she is, just not running right |
| 08-07-2018, (Subject: Here she is, just not running right ) Post: #19 | |||
| RE: Here she is, just not running right You have one I can see the stainless steel tubing that runs to it on your videos. It looks like this and its under your air compressor. If you dont have one then you have major problems. Used Cummins Insite or Cummins quick-serve at https://www.google.com/url?sa=t&source=w...IkKF7OVn_v to register your engine and follow the troubleshooting tree for those codes. It has detailed directions with resistance specifications, voltages and everything on how to test that module and wiring. | |||
| 08-18-2018, (Subject: Here she is, just not running right ) Post: #20 | |||
RE: Here she is, just not running right (08-07-2018 )Chamberpains Wrote: You have one I can see the stainless steel tubing that runs to it on your videos. It looks like this and its under your air compressor. so i took the module of today and popped it open to see what kind of shape its in. it looks old but nothing look fryed. im going to go to harbor freight n get a volt tester and check it out. User's Signature: The creator said " Help your self and I will help you; Protect your self and I will protect you " | |||
