Turbo air filter....
09-27-2019, (Subject: Turbo air filter.... )
Post: #19
RE: Turbo air filter....
(09-27-2019 )Rawze Wrote:
(09-27-2019 )DDlighttruck Wrote:  Swing and a miss. 110 psi going to that actuator circuit. Well, technically, it gets whatever the truck has for air, it went from zero to 110 as the truck built air back up
Put an adjustable regulator on it. Set it for 90 psi.
One like that?
Post: #20
One like that?
yeah. Merik4792 put one on the supply line to the controller on his truck when he was here visiting and it did a world of good for it.
09-28-2019, (Subject: Turbo air filter.... )
Post: #21
One like that?
Will do. Thanks
Post: #22
Fed regulated shop air to the system. The only leak was that fitting. Added a regulator, cut out the 1/4” line, new 3/8” line to a new fitting.
The trucks been shut off for around 5 minutes and the gauge still hasn’t moved. It’s a little crude but it’ll work for now I think
10-31-2019, (Subject: Turbo air filter.... )
Post: #23
Picked up my new actuator today. Came with new bolts, clip, cover and o-rings. About $575 CDN money
Gonna try to get it installed this weekend
 Thanks given by: DosGatos , Chamberpains
