|     Cummins isb 6.7 b101 cm2350 dozing pump issues    |
|    02-02-2021, (Subject: Cummins isb 6.7 b101 cm2350 dozing pump issues )   Post: #19   |  |||
 RE: Cummins isb 6.7 b101 cm2350 dozing pump issues  (02-02-2021 )joed2323 Wrote: Rawze, unless I'm not following you, DT90420 is this the same ecm calibration as DT90426.06? I saw the mistake when you posted the other photos and went back and checked the DT90426 program too. Everything I said above still stands, as there are very little differences in the 420 vs. the 426... therefore I left my post above alone. I can only assume you have the wrong program in your engine and that at some point, some moron tried to up the HP in it by jumping CPL's ... this is what all data points to so far that has been provided on the forum here. if I owned it, I would start by putting the 100% matching and correct program (latest revision) back into the truck and go from there. That is rule#1 when someone comes on here and says they have emissions system issues and can't figure out how to solve them. - Wrong program or Wrong power level settings for the exhaust system you have on the truck = noting but issues after a while. Seen this so many times it is not funny and a after a while someone has nothing but problems due to some jack-leg trying to get more out of their engine and doing this. I have even seen OEM st$ealersh%its do this to people's engines. OEM shops are typically just as clueless as anyone eles out there who would do such a thing. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!.  |  |||
|    02-03-2021, (Subject: Cummins isb 6.7 b101 cm2350 dozing pump issues )   Post: #20   |  |||
 RE: Cummins isb 6.7 b101 cm2350 dozing pump issues  (02-02-2021 )Rawze Wrote:(02-02-2021 )joed2323 Wrote: Rawze, unless I'm not following you, DT90420 is this the same ecm calibration as DT90426.06? Ok, so I was able to get truck over to a cummins dealer for the ecm calibration update. They agreed the wrong cal was installed on truck. They checked over the dosing module/def sending unit/def dosing injector and found nothing wrong with any of it. The cummins tech said that the issue if it comes back has to be with fords wiring or wire they run from the dosing module up to the ecm. He also said that he isn't sure which wire it is and would have to ohm out the wires to find fords wiring since Ford doesn't offer schematics. So drove truck about 20mins and imagine that the same issue came back with losing def pressure just like previously. One thing I noticed is that the def fluid dosing valve commanded position never changes from closed. I did happen to catch it as i was driving and monitoring insite, it changed from closed to open like for a split second but it was fast and it never stayed open only closed It never goes to open even when the def dosing unit state says its dosing, this can't be correct? The cummins tech did say it is possible that the dosing module that was recently changed is faulty. But the dosing module did pass the def module override test and he said it injected enough def into the beaker and flow tested fine. When it builds to 130psi, it holds pressure and voltage for a bit, but when it looses it, it is a slow drop of pressure and volts down to about 0.6 psi/0.8v Its a repeated cycle over and over while driving, def pressure builds to about 130-143psi and then slowly drops back off to 0.6psi, it stays at 0.6 psi for a bit then climbs back up to 130psi and stays their for a bit and then drops slowly back off again. The only code it is currently throwing is: 3574 Now I'm back to square one again, fml  |  |||
|    02-03-2021, (Subject: Cummins isb 6.7 b101 cm2350 dozing pump issues )   Post: #21   |  |||
|  RE: Cummins isb 6.7 b101 cm2350 dozing pump issues    Do you have a cummins quickserve account? If not you need to open one, it's free and only takes a few minutes. Once you do that you can enter your esn and have access to all the wiring diagrams(cummins not truck manufacturer) and part numbers, service information for that exact engine. You can put the fault codes in and follow the troubleshooting tree to help figure out your problems. I know you said it's not active anymore but I'm curious about fault 1682.     |  |||
|    02-03-2021, (Subject: Cummins isb 6.7 b101 cm2350 dozing pump issues )   Post: #22   |  |||
 RE: Cummins isb 6.7 b101 cm2350 dozing pump issues  (02-03-2021 )tree98 Wrote: Do you have a cummins quickserve account? If not you need to open one, it's free and only takes a few minutes. Once you do that you can enter your esn and have access to all the wiring diagrams(cummins not truck manufacturer) and part numbers, service information for that exact engine. You can put the fault codes in and follow the troubleshooting tree to help figure out your problems. I know you said it's not active anymore but I'm curious about fault 1682. Yes I have it. From what I'm being told I need fords wiring schematic not cummins. I'm also noticing the def fluid dosing valve commanded position open/close more then I originally thought. Its very fast when it switches from closed to open but this can't be correct. It should stay open when the diesel exhaust fluid dosing state is "dosing " This is gotta be my issue, but why?  |  |||
|    02-03-2021, (Subject: Cummins isb 6.7 b101 cm2350 dozing pump issues )   Post: #23   |  |||
 RE: Cummins isb 6.7 b101 cm2350 dozing pump issues  (02-03-2021 )joed2323 Wrote: Yes I have it. From what I'm being told I need fords wiring schematic not cummins. sign up onto quickserv ... follow thru these procedures and look for things that may be bad... https://quickserve.cummins.com/qs3/porta...n/2883567/ and... https://quickserve.cummins.com/qs3/porta...n/2883567/ and... https://quickserve.cummins.com/qs3/porta...n/2883567/ Look for old hoses or air lines that may be leaky, etc. The programming for the doser valve shows that the valve will not open unless there is at least 36 psi of "Air Push" pressure at the pump. I don't own one of these trucks, so I am not sure what they are referring to there. Programming also says something about 2 seconds on-time and 20 seconds off-time as the air purge cycle. Maybe what your seeing is this cycle repeating itself? .. unsure... just poking at it from the 10,000 foot viewpoint. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!.  |  |||
