tune up |
03-01-2016, (Subject: tune up ) Post: #19 | |||
RE: tune up (02-27-2016 )sbtrucking Wrote: looks like it was cleaned around 100k miles ago if I have to guess, the egr valve and the egr cooler, turbo, and actuator looks like have been replaced around the same time A picture is worth 1,000 Delta-P sensors? That will cause fuel mileage loss, EGR valve positioning problems, and regen issues. - - - BTW - Regular Rotella-T has better wear protection than T6 according to that oil chart that used to be posted on the old site. | |||
03-03-2016, (Subject: tune up ) Post: #20 | |||
RE: tune up thanks for catching the crack, I will replace the hoses, r they special made hose? interesting I thought synthetic would be better more resistant to heat and dilution brakedown, do you have a link to the tests please | |||
03-03-2016, (Subject: tune up ) Post: #21 | |||
RE: tune up (03-03-2016 )sbtrucking Wrote: thanks for catching the crack, I will replace the hoses, r they special made hose? Yes, they are a special hose/line. I bought mine at my local Cummins shop, I think I paid $40 for the pair. They should be a regular stock item, they were at my shop. And they were a bitch to get on, at least on my motor, a little force was needed. | |||
