Trailer leveling valve
02-29-2016, (Subject: Trailer leveling valve )
Hi fellows, my trailer height at fifth wheel from the ground to the belly is 46", but at the middle of the trailer's axle is 43". Vehicle was on the scale when checked. I think i should adjust trailer's leveling valve to have same height. Am I right?
RE: Trailer leveling valve
You need to find out what the ride height is for your trailer suspension. If you try to get both level,you may be in for a rough ride.
(02-29-2016 )Sergiu Wrote:  Hi fellows, my trailer height at fifth wheel from the ground to the belly is 46", but at the middle of the trailer's axle is 43". Vehicle was on the scale when checked. I think i should adjust trailer's leveling valve to have same height. Am I right?
Try this
Attached File(s)
.pdf  L459.pdf (Size: 491.1 KB / Downloads: 876)
