| How does the oil bypass valve work? |
| 10-18-2016, (Subject: How does the oil bypass valve work? ) Post: #1 | |||
| How does the oil bypass valve work? I am curious about the relief or bypass spring valve in the oil filter base. I see there is a update, bulletin 4908439. I tried to buy the update but they sold me the original. I am curious how this bypass works? at a certain psi does it open and feed oil back into the cooler? what is the psi? Any idea what the update fixed? User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
| 10-18-2016, (Subject: How does the oil bypass valve work? ) Post: #2 | |||
| RE: How does the oil bypass valve work? So according to this bulletin, all ISX's are affected prior to April 2015 then? You purchased part # 4357177, and it was the old style pictured in the bulletin they say to discard? That doesn't seem right. How much was the part? Thanks Brock, it's only a lubricating oil related part...now I'm stressing! I need beer! As far as how it works, from Quickserve: Whenever the pressure drop across the lubricating oil filter exceeds 862 kPa [125 psi], the oil filter bypass valve opens and allows lubricating oil to bypass the lubricating oil filter. This condition can occur during cold ambient (cold lubricating oil) engine start-ups. The purpose of the bypass valve is to maintain lubricating oil flow to the engine and prevent an oil filter collapse. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
| 10-18-2016, (Subject: How does the oil bypass valve work? ) Post: #3 | |||
| RE: How does the oil bypass valve work? I don't know what my problem is with quickserve but I can never find anything, couldn't even search for this bulletin. i had to Google it, maybe it doesn't like my mobile browser. Thanks hammer User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
| 10-19-2016, (Subject: How does the oil bypass valve work? ) Post: #4 | |||
RE: How does the oil bypass valve work? (10-18-2016 )Brock Wrote: I am curious about the relief or bypass spring valve in the oil filter base. I see there is a update, bulletin 4908439. I tried to buy the update but they sold me the original. It works like this ... User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
