| Chevrolet 2500 Duramax diagnostic programs |
| 03-05-2026, (Subject: Chevrolet 2500 Duramax diagnostic programs ) Post: #1 | |||
| Chevrolet 2500 Duramax diagnostic programs Good afternoon everyone. My question is are there any programs out that can be used with a Cummins Inline 6 data link adapter that can be used to diagnose a check engine light on a 2013 Chevrolet 2500HD? Id like to be able to find out what's causing a check engine light to come on. | |||
| 03-06-2026, (Subject: Chevrolet 2500 Duramax diagnostic programs ) Post: #2 | |||
| RE: Chevrolet 2500 Duramax diagnostic programs There are ways to get connected and se what the codes are in Insite I believe. you might have to go under the hood to get connected. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| Yesterday, (Subject: Chevrolet 2500 Duramax diagnostic programs ) Post: #3 | |||
| RE: Chevrolet 2500 Duramax diagnostic programs You can get a cheap elm327 adapter for around 20 bucks on Amazon. Then an app like Torque on the Google play store or equivalent program for apple. Ive set up quite a few friends with similar set ups. I know dodges you can connect with insite under hood but it is typically easier using an elm327 adapter and a program like torque. | |||
