| Low oil pressure on gauge? |
| 10-26-2016, (Subject: Low oil pressure on gauge? ) Post: #1 | |||
| Low oil pressure on gauge? I'm going crazy right now. Fault code for low oil pressure, but does not shut down. This is oil that has been changed less than 5 hours ago of runtime, delvac 15/40 per Mhc rebuild instruction. This is a 2011ISX cm2250 450hp/ 1650 tq, col 3719 and only 4,000 miles on inframe. I'm guessing sensor is bad for oil pressure? | |||
| 10-26-2016, (Subject: Low oil pressure on gauge? ) Post: #2 | |||
| RE: Low oil pressure on gauge? I would start with oil pressure sensor since it's pretty cheap to replace. What oil pressure are you getting? Was you're oil pump replaced with inframe? | |||
| 10-26-2016, (Subject: Low oil pressure on gauge? ) Post: #3 | |||
| RE: Low oil pressure on gauge? Not sure if oil pump was replaced? It's not my truck but I could lease it. Truck was running 40 psi and 30 psi idle untill yesterday when it stated acting up. I figure if no oil was being pumped the engine would shut down per safety features??? | |||
| 10-26-2016, (Subject: Low oil pressure on gauge? ) Post: #4 | |||
| RE: Low oil pressure on gauge? What oil pressure are you getting now? | |||
| 10-26-2016, (Subject: Low oil pressure on gauge? ) Post: #5 | |||
| RE: Low oil pressure on gauge? 0 at high idle of 1000rpm. No engine shut down warning? | |||
| 10-26-2016, (Subject: Low oil pressure on gauge? ) Post: #6 | |||
| RE: Low oil pressure on gauge? I would try sensor first, filter and if nothing after thathe you have a serious problem. | |||
| 10-26-2016, (Subject: Low oil pressure on gauge? ) Post: #7 | |||
| RE: Low oil pressure on gauge? Pump seems to be original old looking. Where is the oil sensor? | |||
| 10-26-2016, (Subject: Low oil pressure on gauge? ) Post: #8 | |||
| RE: Low oil pressure on gauge? Does Jakes still work good? It takes good oil pressure for those to work. Thats what I guage by when Im on the road and something like this happens to me. | |||
| 10-26-2016, (Subject: Low oil pressure on gauge? ) Post: #9 | |||
| RE: Low oil pressure on gauge? Driver side of the engine by ecu | |||
