CM2250 Leaking doser
01-03-2017, (Subject: CM2250 Leaking doser )
RE: CM2250 Leaking doser
(01-03-2017 )Waterloo Wrote:  Gearhead is right there in MD off of I-95, he has a full functioning shop... Take it to him if you are up that way. That is where I would go.
Been there.
Met the man.
I second this all day long! If you're in his area, you won't go wrong taking it to him. In fact you're probably further ahead rectifying the problem ASAP witb a reputable shop/guy than you are waiting to get home!
Sounds great, I just semt him an email. Thanks for the info all!
(01-03-2017 )fargonaz Wrote:  Sounds great, I just semt him an email. Thanks for the info all!
Not trying to promote him, just providing info if you need to get there. Here is the info.
http://rawze.com/forums/showthread.php?t...36#pid5536
 Thanks given by: fargonaz
OK, confused now(I know, too easy) is this Gearhead's place or another place that does good work also?
 Thanks given by: hhow55
(01-03-2017 )fargonaz Wrote:  OK, confused now(I know, too easy) is this Gearhead's place or another place that does good work also?
This is Gearhead's place, and you won't be disappointed.
Great Guy
Thanks again. I'll give him a buzz after I'm loaded in the morning.
(01-03-2017 )fargonaz Wrote:  Thanks again. I'll give him a buzz after I'm loaded in the morning.
That's a good decision right there.
They are Grade A people.
01-04-2017, (Subject: CM2250 Leaking doser )
Didn't go, I made bad things happen with cargo today(busted door off.) Spent most of the day enduring high drama and lectures.
It wasn't leaking this morning either, the temperature was 43 both this morning and last, previously it was in the teens and 20's. It's going to get cold tonight so I'll keep checking.
