| CM871 egr plug |
| 01-05-2017, (Subject: CM871 egr plug ) Post: #1 | |||
| CM871 egr plug What are the dimensions of the plug that goes between the exhaust manifold and the erg on a mandated engine? | |||
| 01-05-2017, (Subject: CM871 egr plug ) Post: #2 | |||
| RE: CM871 egr plug Assuming you live in a country that allows such mods, perhaps it would be best to pull the manifold off and take some measurements? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
