Big Truck Technical Discussion...
Ask Your question...
> CM871 egr plug
Full Version:
CM871 egr plug
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
Tdaent06
01-05-2017,
What are the dimensions of the plug that goes between the exhaust manifold and the erg on a mandated engine?
Rawze
01-05-2017,
Assuming you live in a country that allows such mods, perhaps it would be best to pull the manifold off and take some measurements?
> CM871 egr plug
Reference URL's
Rawze.com: Rawze's ISX Technical Discussion and more:
http://rawze.com/forums/index.php
