Outboard 2 cycle oil?
01-13-2017, (Subject: Outboard 2 cycle oil? )
If you had a demandated cm2250 would there be any reason you might want to run outboard oil. I really like it in my older diesels. I know this is a totally different animal but seems like that high pressure system might like alittle more lube.
RE: Outboard 2 cycle oil?
I mention it in this article...
http://rawze.com/forums/showthread.php?t...622#pid622
 Thanks given by: kmk
I've read that article. That's were I got the idea. I notice in my other older equipment that it seems to clean injectors. Not sure how or maybe the equipment just cleaned up from hard use after I bought it. I have a old iron, and farming habit. Any how is their something in 2 cycle outboard oil that cleans up carbon in the combustion camber?
Buddy of mine runs it in his Powerstroke. He says it runs smoother and better.
01-14-2017, (Subject: Outboard 2 cycle oil? )
(01-13-2017 )Magard Wrote:  I've read that article. That's were I got the idea. I notice in my other older equipment that it seems to clean injectors. Not sure how or maybe the equipment just cleaned up from hard use after I bought it. I have a old iron, and farming habit. Any how is their something in 2 cycle outboard oil that cleans up carbon in the combustion camber?
Dude, you are trying to improve the mandate elimination... LOL! Pretty sweet eh?
 Thanks given by: Magard
It is said that there is no liquid cure if you have clogged injectors, but there are a couple products that will help prevent it.
Waterloo, Just don't like to leave any stones unturned. You know!! Hey!!
I ve always used two stroke oil when i would run jet-A (Jet fuel has very little lubricates in it and is close to K1) in my powerstroke. The fuel farm where i used to work was sumped daily to check for water. With Jet A in the truck it didnt have as much power and get as good mpg as diesel but free is good! Also i use walmart 2 stroke in my C12 but only in very small quanities and have no data but i feel its helping my engine. FWIW
