Humming Noise With Key Turn On
01-18-2017, (Subject: Humming Noise With Key Turn On )
After I start my truck isx 871 prostar and cut the truck off and turn the key on. I can hear aloud buzzing or wining noise, it seem to become from IFMS but I am not for sure t. I have replace the gear pump about 3 weeks ago... Thank you in advance for your input!!!!!!
User's Signature: I stand on a square, I am always seeking light... Just old traveling man lost in the wilderness my compass is pointing me to the East!!!!
RE: Humming Noise With Key Turn On
The buzzing noise us you electric fuel lift pump.
 Thanks given by: fargonaz , rgreen
(01-18-2017 )hhow55 Wrote:  The buzzing noise us you electric fuel lift pump.
Btw, the buzzing noise means it is working. Mine does the same.
 Thanks given by: in2trux , Waterloo , rgreen
I was going to say, I was will replace tomorrow but you said it means it working... Thank you!!!!
01-19-2017, (Subject: Humming Noise With Key Turn On )
(01-18-2017 )rgreen Wrote:  After I start my truck isx 871 prostar and cut the truck off and turn the key on. I can hear aloud buzzing or wining noise, it seem to become from IFMS but I am not for sure t. I have replace the gear pump about 3 weeks ago... Thank you in advance for your input!!!!!!
That would highly depend on what you are hearing.
Here is what a healthy electric fuel pump sounds like on a CM871. it is at 1:21 in the video...
 Thanks given by: rgreen
Thank Rawze that how mine sound.
