oil blow out crank case filter
04-09-2017, (Subject: oil blow out crank case filter )
Had a oil filter clog up 14 days after service then put new filter on crank case filter light came
on and off lost about a gal. of oil out blow of tube clean of oil pan getting no new lights
no more oil blowing out of crank case any one know what could be the problem??
04-10-2017, (Subject: oil blow out crank case filter )
RE: oil blow out crank case filter
possible blown o'rings on your Turbo, do you have excessive blow-by?
User's Signature: In the immortal words of Romeo as he gazed upon Juliet's eyes..."Wait...We Drank What?!"
 Thanks given by: hhow55
04-11-2017, (Subject: oil blow out crank case filter )
it all seem to stop no oil coming out of crank case filter anymore no dash lights
it does sometimes run hotter than normal
(04-10-2017 )Hedley Wrote:  possible blown o'rings on your Turbo, do you have excessive blow-by?
I have the same problem...oil out the tube i took it to kenworth dealer and first thing they said was an overhaul...
 Thanks given by: dunwitit
04-12-2017, (Subject: oil blow out crank case filter )
a clogged DPF and DOC will produce the same effects, engine can't breath so it pushes oil through the crankcase breather tube.
04-13-2017, (Subject: oil blow out crank case filter )
I notice oil only come out when regen come while I'm rolling
The shop is changing my crankcase filter and doing force regen...is a force regen better ???
Stealerships do a forced regen anytime they work on a truck. Whether it needs one or not. Inframe the truck, force regen. Replace a sensor. Forced regen. Roll the hood. Forced regen. They love doing those damn things.
