bad oil cooler |
04-26-2017, (Subject: bad oil cooler ) Post: #10 | |||
RE: bad oil cooler there was no gasket in the box with oil cooler, have measured old one with new one and new one is slightly thinner, old one gas bottom/side where meets plain , new one is extended need a gasket there, right? have it figured out,there were two orings in the bag from the dealer | |||
04-29-2017, (Subject: bad oil cooler ) Post: #11 | |||
RE: bad oil cooler reassembled. flushed radiator twice with "simple green" ( 3 gal green 9 water) 3rd time 2 gallons of red coolant and rest water, still have some oil residue at the top of water tank ( put new one) will drive it a little on Monday and see what happens, will try to test old cooler also for leak regarding torquing * 75 ft-lbs torque on turbo mounting bolts instead of what the book says. book says 75 on turbo mounting bolts 35 ft-lbs for oil cooler 44 ft-lbs for manifold friends of mine recommended more torque but followed the book only put 95 ft lb on turbo any thoughts on torquing for future??? the engine has 1.2mil miles when idling and when I take oil dipstick out it is pournig oil - is this engine done??? Thank you in advance | |||
04-29-2017, (Subject: bad oil cooler ) Post: #12 | |||
RE: bad oil cooler "when idling and when I take oil dipstick out it is pournig oil" you mean its blowing out the dipstick tube??? | |||
04-30-2017, (Subject: bad oil cooler ) Post: #13 | |||
RE: bad oil cooler yes , oil goes out of dipstick tube and when remove cap from oil fill tube oil stops blowing out | |||
04-30-2017, (Subject: bad oil cooler ) Post: #14 | |||
RE: bad oil cooler Usually flush it out with dish soap and water a few times. User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
04-30-2017, (Subject: bad oil cooler ) Post: #15 | |||
RE: bad oil cooler Fleetguard Cummins Restore Coolant System Cleaner User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
04-30-2017, (Subject: bad oil cooler ) Post: #16 | |||
RE: bad oil cooler (04-29-2017 )ktbtrucking Wrote: ... If you have oil coming out the dipstick tube, this indicates excessive crankcase pressure to me, and removing the dipstick relieves the pressure while also pushing oil out the dipstick tube, that becomes relieved when you remove the very oversized (relative) oil fill cap. I suspect the following; 1)Crankcase breather filter is plugged 2)Crankcase breather vent hose from the filter housing to atmosphere is plugged both of these situations would be instantly relieved by the fill cap 3)Turbo seals are leaking excessive pressure into the crankcase 4)Cylinder rings are worn or cylinders are glazed enough to allow excessive blowby for the crank breather and the dipstick tube, but not also the fill tube 5)Significant internal cylinder pressure leakage from time and wear indicating an overhaul is or is soon to be required All the chemicals in the world to clean the oil residue from the surge tank will do nothing to solve the crankcase pressure issue. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
05-01-2017, (Subject: bad oil cooler ) Post: #17 | |||
RE: bad oil cooler (04-30-2017 )Brock Wrote: Usually flush it out with dish soap and water a few times. I do not recommend this at all. It takes 20 flushes to get all the dish and/or dishwasher soap out, and even then, red coolant does not last long before ph goes bad. I went through that nightmare, will never do it again!. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
05-01-2017, (Subject: bad oil cooler ) Post: #18 | |||
RE: bad oil cooler (04-26-2017 )Rawze Wrote:(04-25-2017 )ktbtrucking Wrote: have cm 870, removed all parts today, there was no access/ or limited access to top screws of egr cooler so had to remove exhaust manifold to remove egr cooler Rawze I want to know the reason why you recommend using only a very tiny amount of anti seize. As a man this goes against everything I know......more is always better...lol. | |||
