aftertreatment injector
05-20-2017, (Subject: aftertreatment injector )
will aft injector fire at shutoff
I was doing leak test and got sprayed
after i cut engine off
RE: aftertreatment injector
Yikes! Fuel or DEF? I think they both purge when you shut the key off.
fuel
a short burst
05-27-2017, (Subject: aftertreatment injector )
(05-20-2017 )jman1978 Wrote:  fuel
a short burst
I don't know whether this is normal or not. Logically it makes sense to relieve the pressure with a short burst, otherwise the residual heat would expand the fuel after shutdown, potentially causing over pressure damage in a closed circuit.
I think the after treatment fuel injector purges on shut off because you can take the fuel line off the top when the truck is off and there is no fuel present.
