Cm570 build
07-12-2017, (Subject: Cm570 build )
Post: #19
RE: Cm570 build
As it sits . Need to get a couple of thermostats and plug up an engine harness and it's good to go
 Thanks given by: Brock , Hedley , Running rough , Hammerhead , gatow900 , Signature620 , hhow55 , fargonaz , Roysbigtoys
Post: #20
RE: Cm570 build
Beautiful. Real nice work. When's the transplant?
 Thanks given by: AussieISX
Post: #21
RE: Cm570 build
Sweet. Like one of your country men You Tube stars would say, "can't wait to see you kick her in the guts". The guy uses the name "Alwaysoffroad" and here is a little vid of him pulling a triple road train grossing 115 tons.
 Thanks given by: gatow900
Post: #22
RE: Cm570 build
I think I need a tissue and a moment...
Very nice! I really like the modified size c/c breather!
where's the jealous emoticon?
 Thanks given by: Waterloo , AussieISX , Old Driver
07-13-2017, (Subject: Cm570 build )
Post: #23
RE: Cm570 build
(07-12-2017 )Rig Wrench Wrote:  Beautiful. Real nice work. When's the transplant?
Thanks, probably fit it between the rails in the next fortnight, I'm out in the truck again for s week or so tomorrow.
Post: #24
RE: Cm570 build
(07-12-2017 )Hammerhead Wrote:  I think I need a tissue and a moment...
Hahahaha, might look pretty but hopefully I got it right. First fire up will be a nervous time !!!
 Thanks given by: Hammerhead , Nilao
Post: #25
RE: Cm570 build
I know that first start feeling after it's reassembled. Everyone stand back. It might grenade. Lol
 Thanks given by: Hammerhead , AussieISX
07-16-2017, (Subject: Cm570 build )
Post: #26
RE: Cm570 build
I know proper building of the motor is of utmost importance,but I so appreciate when it looks good too. Great job!
 Thanks given by: Rawze , AussieISX , Brock
07-26-2017, (Subject: Cm570 build )
Post: #27
RE: Cm570 build
Bit of progress the last couple of days. Should be making noise by the weekend. Fitted up a new 2050 easy pedal clutch and did a heap of re-ferb work on the harness. Re bushed the spring mounts on the chassis and painted and fitted new springs while the engine was out . Still need to strip and clean the radiator and fit new gaskets on the tanks
 Thanks given by: gatow900 , Rawze , Texasdude74 , BobsYourUncle , Signature620 , Dd614 , Hammerhead , hhow55 , Brock , fargonaz
