|  Fuel Delivery Pressure  |
|  07-02-2017, (Subject: Fuel Delivery Pressure )  Post: #1 | |||
| Fuel Delivery Pressure  2008 CM 871 getting an intermittent "fuel delivery pressure" code. It doesn't seem to affect anything just a cel. Any ideas appreciated. Thanks.  | |||
|  07-02-2017, (Subject: Fuel Delivery Pressure )  Post: #2 | |||
| RE: Fuel Delivery Pressure  could be getting air in the system or it could be a pressure regulator with trash in it. It could also be a failing shutoff solenoid. they can cause it too. Just some places to look. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  07-02-2017, (Subject: Fuel Delivery Pressure )  Post: #3 | |||
| RE: Fuel Delivery Pressure | |||
|  07-03-2017, (Subject: Fuel Delivery Pressure )  Post: #4 | |||
| RE: Fuel Delivery Pressure  Every single time a mechanic changes my davco fuel filter, I get this code. It's high time I buy a new plastic cover as mines a asshole to install back on. It sucks air and I get that code.  User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
|  07-03-2017, (Subject: Fuel Delivery Pressure )  Post: #5 | |||
| RE: Fuel Delivery Pressure  Check what the engine was doing when the faults were active. You'll get this code if you try and start it while there's still air in the fuel filters during a service.  | |||
|  07-03-2017, (Subject: Fuel Delivery Pressure )  Post: #6 | |||
| RE: Fuel Delivery Pressure  I will know for sure in a day or so but I think I might be sucking air in my fuel tank. Maybe a cracked suction tube cause I was down around a quarter tank when it was doing it. I fuelled up last night and it stopped so far. Thanks for the heads up for air in my fuel.  | |||
