|  Actuator abnormal update rate  |
|  07-15-2017, (Subject: Actuator abnormal update rate )  Post: #1 | |||
| Actuator abnormal update rate  Replaced my turbo, used my old VGT actuator which was in good shape. Installed it with insite passed calibration. After driving couple hours I keep getting a 2636 code stating abnormal update rate. Took it off and recalibrated again and same thing keeps happening. Is it a bad actuator or am I missing anything? THANK ALL | |||
|  07-15-2017, (Subject: Actuator abnormal update rate )  Post: #2 | |||
| RE: Actuator abnormal update rate  Check the pins in the plug for dirt or corrosion. Make sure the female side pin is not spread to far out.  | |||
|  07-16-2017, (Subject: Actuator abnormal update rate )  Post: #3 | |||
| RE: Actuator abnormal update rate  Check the connections. Make sure also that the wiring does not get close to the exhaust housing. it can get melted.  User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
