| Tire rolling resistance (copied from another forum). |
| 03-15-2016, (Subject: Tire rolling resistance (copied from another forum). ) Post: #1 | |||
| Tire rolling resistance (copied from another forum). My own thought on Tire rolling resistance comes from talking to others, and from dealing with my own truck. My own conclusions are that Tire rolling resistance is VERY important on trucks that carry heavy freight, but trucks that carry light weight freight, rolling resistance has little to no measurable effect on fuel mileage. As well, the faster or slower you go down the freeway, the more or less effect it will have too. The slower you drive, the less tire rolling resistance comes into play as well. Also, how much air pressure you have in your tires plays a huge roll in how effective a low-rolling resistive tire actually is. I inflate my own tires to a full 120 psi to get the most out of this, and have never had an issue with doing this. My own opinion is that rolling resistance, its importance, and how much it effects your fuel costs is really based on several factors. The biggest being how fast you drive, and how heavy your truck is most of the time. I use the lowest rolling resistance tires I can get, because I am usually heavy due to reefer freight, but I do not drive fast. I stay around 57-60 mph, but even so, low rolling resistance helps me save enough fuel to justify the extra costs of these types of tires. If I were only pulling light freight, it probably would not matter much, and just about any tire would work fine. Also, the lower the tread a tire has, the more efficient it becomes. This means that if your pulling heavy freight all the time, it is better to have worn down tires than new ones if you want to save fuel. --- I wanted to put this here for others on this site. I copied it from another forum, nothing more... This is the rolling resistance chart of several brands of tires AS lifted from another forum out there. Tire Rolling Resistance ====================== Brand Model RR ====================== Accutread (retread) XML Drive 196 Aeolus HN308 134 Aeolus HN329 144 Bandag (retread) BDM 172 Bandag (retread) BDR A/S 220 155 Bandag (retread) BDR ULTRA WIDE DRIVE 380 145 Bandag (retread) BDR-HT 220 192 Bandag (retread) BDR-W 220 26 186 Bandag (retread) BDV 230 148 Bandag (retread) BRM 158 Bandag (retread) BRR-UWB 390 120 Bandag (retread) BTL-SA 220 126 Bandag (retread) BTR ULTRA WIDE TRAILER 380 92 Bandag (retread) D4300 178 Bandag (retread) D4310 152 Bandag (retread) ECL DRIVE 146 Bandag (retread) ECL RIB 138 Bandag (retread) ECL TRAILER 122 Bandag (retread) ECLDSN3 148 Bandag (retread) Eclipse ST-M 220 129 Bandag (retread) FCR-D 220 20 154 Bandag (retread) FCR-Rib 230 131 Bandag (retread) FCR-T 220 11 108 Bandag (retread) FCR-T 230 112 Bandag (retread) FUEL TECH-D 220 24 118 Bandag (retread) FUEL TECH-T 220 12 96 Bandag (retread) Gripper 220 169 Bandag (retread) Highway 9 - 219 130 Bandag (retread) HS 124 Bandag (retread) MEGA TREK 220 170 Bandag (retread) R4200 9" 156 Bandag (retread) R4200 9" 156 Bandag (retread) T4100 138 Bandag (retread) UAP 141 Bandag (retread) UDR 220 190 Bandag (retread) WH RIB 160 BFG DR434 141 BFG DR444 140 BFG DR665 158 BFG REG. LUG 137 BFG REG. RIB 105 BFG REG.TRAILER 96 BFG ST230 106 BFG ST234 114 BFG ST565 128 BFG TR144 99 Bridgestone Greatec Drive S892WZ 128 Bridgestone Greatec Trailer S169 YZ 99 Bridgestone L312 97 Bridgestone L317 159 Bridgestone L320 138 Bridgestone M711 154 Bridgestone M720 110 Bridgestone M724Z 154 Bridgestone M725 172 Bridgestone M726 177 Bridgestone M726 EL 141 Bridgestone M729 161 Bridgestone M748 116 Bridgestone M774 153 Bridgestone M775 153 Bridgestone M843 114 Bridgestone M844 101 Bridgestone M844F 97 Bridgestone M857 133 Bridgestone M860 108 Bridgestone R184 115 Bridgestone R187 135 Bridgestone R187F 116 Bridgestone R194 109 Bridgestone R194 WB 86 Bridgestone R195 F 95 Bridgestone R196 111 Bridgestone R226 131 Bridgestone R227 108 Bridgestone R227 Cz 107 Bridgestone R227XZ 135 Bridgestone R250 ED 112 Bridgestone R250F 123 Bridgestone R260F 138 Bridgestone R270 116 Bridgestone R280 109 Bridgestone R287 119 Bridgestone R290 140 Bridgestone R293Z 145 Bridgestone R294 150 Bridgestone R296 119 Bridgestone R299 112 Continental HDC 142 Continental HDL 144 Continental HDL Eco Plus 116 Continental HDL-A 106 Continental HS45 107 Continental HSC 117 Continental HSL AE+ 113 Continental HSL Eco+ 111 Continental HSL2 105 Continental HSR 113 Continental HSR1 110 Continental HSU 115 Continental HTL 100 Cooper CT240 97 Double Coin RLB1 129 Double Coin RLB400 167 Double Coin RLB900 104 Double Coin RR100 123 Double Coin RR11 167 Double Coin RR150 124 Double Coin RR300 122 Double Coin RR9 167 Double Coin RT500 107 Dunlop SP131 104 Dunlop SP160 117 Dunlop SP361 122 Dunlop SP381 136 Dunlop SP431 134 Firestone City Transport 143 Firestone FD663 138 Firestone FD690 + 161 Firestone FS400 113 Firestone FS560 + 121 Firestone FS590 + 123 Firestone FT455 100 Firestone HP3000 110 Firestone T545 104 Firestone T559 116 Firestone T589 138 Firestone T663 158 Firestone T831 153 Firestone UT2000 110 General AMER*MSL 120 General AMERI LUG 159 General AMERI RIB 179 General AMERI RIB ST 118 General AMERI STEEL 120 General D440 150 General D460 140 General D660 139 General S330 137 General S350 126 General S380 127 Goodyear G104 RST 104 Goodyear G114 117 Goodyear G124 - Retread 161 Goodyear G132 115 Goodyear G149 RSA 128 Goodyear G152 MetroMiler 141 Goodyear G159 133 Goodyear G159 220 - Retread 132 Goodyear G159A 230 16 - Retread 139 Goodyear G167 158 Goodyear G167 220 - Retread 159 Goodyear G169 RSA 121 Goodyear G175 155 Goodyear G177 151 Goodyear G178 125 Goodyear G182-RSD 166 Goodyear G182-RSD 230 - Retread 154 Goodyear G244 164 Goodyear G259 123 Goodyear G286 129 Goodyear G287 HSS - Duraseal 109 Goodyear G287 MSA 128 Goodyear G287 MSA - Duraseal 109 Goodyear G291 145 Goodyear G302 110 Goodyear G302 FED 220 - Retread 117 Goodyear G305 FuelMax 114 Goodyear G305 FuelMax 230 22 - Retread 134 Goodyear G305 FuelMax Unicircle 230 24 - Retread 136 Goodyear G314 116 Goodyear G314 216 - Retread 96 Goodyear G314 230 12 - Retread 116 Goodyear G314 Unicircle 230 12 - Retread 117 Goodyear G316 FuelMax 91 Goodyear G316 FuelMax 230 12 - Retread 114 Goodyear G316 FuelMax UniCircle 230 12 - Retread 110 Goodyear G316 LHT Duraseal 106 Goodyear G328 225 24 - Retread 195 Goodyear G338 155 Goodyear G338 1AD 170 Goodyear G338 220 - Retread 172 Goodyear G357 108 Goodyear G358 LHS 108 Goodyear G362 150 Goodyear G362 FED 220 - Retread 172 Goodyear G362 Unicircle 230 22 - Retread 153 Goodyear G372 139 Goodyear G372 216 - Retread 155 Goodyear G372 Unicircle 230 24 - Retread 152 Goodyear G372A 137 Goodyear G372A 230 22 - Retread 161 Goodyear G392 SSD 116 Goodyear G395 125 Goodyear G395 FuelMax 123 Goodyear G397 128 Goodyear G409 MBA 117 Goodyear G647 RSA 133 Goodyear G647 RSS 139 Goodyear G670 131 Goodyear G670 RV 107 Goodyear Marathon LHS 100 Goodyear Marathon LHT 105 Goodyear UNISTEEL 131 Goodyear UNISTEEL II 155 Goodyear WINGFOOT APR 132 Goodyear WINGFOOT DTR 142 Hankook AL01 115 Hankook AL07 107 Hankook 115 Hankook DL01 134 Hankook F26A 109 Hankook Z59w 127 Kelly KDA 146 Kelly KDM I 152 Kelly KGR 127 Kelly KSA 115 Kelly KTS 100 Marangoni (retread) Kontur TA 390 93 Michelin MD400 119 Michelin MD4x2 149 Michelin MZA3 105 Michelin MZE2 109 Michelin X Coach XZ 105 Michelin XD1 135 Michelin XD2 127 Michelin XD4 153 Michelin XDA 128 Michelin XDA Energy 99 Michelin XDA-HT 150 Michelin XDA2 115 Michelin XDA2+ Energy 116 Michelin XDA3 115 Michelin XDA5 157 Michelin XDE A/T 142 Michelin XDE M/S 157 Michelin XDE2 136 Michelin XDE2+ 131 Michelin XDHT 150 Michelin XDN 138 Michelin XDN2 139 Michelin XDN2 Grip 141 Michelin XDS 147 Michelin XDS2 142 Michelin XDU 141 Michelin XDY-1 150 Michelin XDY-2 153 Michelin XDY-EX 142 Michelin XDY3 128 Michelin XFE 94 Michelin XMS+4 134 Michelin XOne MDA 85 Michelin XOne XDA 94 Michelin XOne XDA-HT 129 Michelin XOne XDA-HT Plus 122 Michelin XOne XDN2 120 Michelin XOne XDU 108 Michelin XOne XRV 92 Michelin XOne XTA 74 Michelin XOne XTE 99 Michelin XOne XTE * 87 Michelin XOne XZU S 109 Michelin XOne XZY3 105 Michelin XRV 91 Michelin XT-1 99 Michelin XTA 133 Michelin XTA Energy 83 Michelin XTA2 Energy 104 Michelin XTE 104 Michelin XTE2 111 Michelin XTE2 wb 91 Michelin XTY2 114 Michelin XZ2 102 Michelin XZA 83 Michelin XZA-1 114 Michelin XZA-1 + 109 Michelin XZA2 103 Michelin XZA2 Antisplash 103 Michelin XZA2 Energy 94 Michelin XZA3 101 Michelin XZA3 Antisplash 104 Michelin XZE 120 Michelin XZE* 120 Michelin XZE2 (Euro design) 114 Michelin XZE2 (NA design) 123 Michelin XZE2+ 114 Michelin XZL(wb) 112 Michelin XZT 130 Michelin XZU2 116 Michelin XZU3 121 Michelin XZU4 123 Michelin XZUS 114 Michelin XZY 115 Michelin XZY(wb) 97 Michelin XZY-1 114 Michelin XZY-2 114 Michelin XZY3 115 MRTI (retread) XD4 220 165 MRTI (retread) XD4 230 164 MRTI (retread) XDA Hypersipe 230 141 MRTI (retread) XDA+ AT 225 23 124 MRTI (retread) XDA-HT 230 152 MRTI (retread) XDA2 A-T 219 19 114 MRTI (retread) XDA2 A-T 219 23 120 MRTI (retread) XDA2 A-T 225 19 109 MRTI (retread) XDA2 A-T 225 23 117 MRTI (retread) XDA2 A-T 23 Custom Mold 111 MRTI (retread) XDC 137 MRTI (retread) XDE M/S 220 152 MRTI (retread) XDHT 159 MRTI (retread) XDN 161 MRTI (retread) XDN 220 143 MRTI (retread) XDN2 230 143 MRTI (retread) XDS 220 138 MRTI (retread) XDU S 240 154 MRTI (retread) XDU S 250 136 MRTI (retread) XDY-1 153 MRTI (retread) XDY3 151 MRTI (retread) XMS4 161 MRTI (retread) XOne XDA 380 95 MRTI (retread) XOne XDA-HT 380 100 MRTI (retread) XOne XDA-HT 390 103 MRTI (retread) XOne XTA 375 13 82 MRTI (retread) XOne XTE 375 109 MRTI (retread) XT-1 102 MRTI (retread) XT-1 A-T 219 98 MRTI (retread) XTA 240 16 122 MRTI (retread) XTA-1 119 MRTI (retread) XZA 230 119 MRTI (retread) XZE 133 MRTI (retread) XZE SA 215 108 MRTI (retread) XZE SA 225 113 MRTI (retread) XZE2 240 20 110 MRTI (retread) XZE2 250 20 110 MRTI (retread) XZU S 240 126 MRTI (retread) XZU S 250 119 MRTI (retread) XZY 137 MRTI (retread) XZY-1 135 Oliver (retread) ULP Drive 390 152 Oliver (retread) ULP Rib 390 121 Oliver (retread) Vantage Drive 230 140 Oncor (retread) M726 143 Oncor (retread) M726/G167 152 Oncor (retread) M726/XD-1 146 Oncor (retread) M726/XDA+ 145 Toyo M120Z 112 Toyo M137 107 Toyo M147 104 Toyo M503Z 149 Toyo M610ZL 129 Triangle TR688 158 Triangle TR689 169 Triangle TR696 118 Yokohama 103 ZR 114 Yokohama 501 ZA 103 Yokohama LY053 135 Yokohama MY507A 89 Yokohama RY023 112 Yokohama RY083 AMC? 93 Yokohama RY083A 112 Yokohama RY112 102 Yokohama RY112AMC? 95 Yokohama RY567 102 Yokohama RY587 98 Yokohama RY617 102 Yokohama RY637 115 Yokohama TY063 147 Yokohama TY063K 140 Yokohama TY203 140 Yokohama TY303 119 Yokohama TY303MC? 115 Yokohama TY517 122 Yokohama TY527 143 Yokohama TY577 130 Yokohama Y703ZL 117 Yokohama Y713 130 Yokohama Y77 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 10-28-2018, (Subject: Tire rolling resistance (copied from another forum). ) Post: #2 | |||
| RE: Tire rolling resistance (copied from another forum). A few weeks ago I swapped out my 726EL’s that were down to 5/32’s to brand new XDN2’s. At the same time I replaced the drums/brakes and recalibrated my speedometer(went from tall to low pro). I figured my 7 mpg average would lose a few tenths, no big deal but I’m struggling to get more than 6.2-6.3, and sometimes less than 6. I’m really thinking next spring of getting some straight treads and having two sets of tires. Bad mileage sucks. User's Signature: That’s pronounced, /ˈs(k)izəm/ | |||
| 10-28-2018, (Subject: Tire rolling resistance (copied from another forum). ) Post: #3 | |||
| RE: Tire rolling resistance (copied from another forum). I invested in 2 sets of drives. M710's and R283's (16-ply). We had the bright idea to use theR283's in the summer because they have a lower rolling resistance than the M710's. Then use the M710's in the winter. The R283's did improve the fuel mileage about 0.3 mpg above the M710's. The only problem is that they would spin out way too often in gravel and in parking lots. They also got dangerous in heavy rains. - They had to go, they were dangerous in my book. We went back to the M710's all year around. We have been using the R283's for steer tire replacements as we need them. Personally, I think the concept is novel, but ... A) Dangerous/Risky for a highway truck. B) If your down in the 6 - 7 mpg range, it is NOT YOUR TIRES that is going to get you any significant gains. It is likely your driving and other things you need to work on long before spending a lot of money on those last few tenths by running lo-roll steers on the back end. That is my own experience any ways. ========= (10-28-2018 )schISM Wrote: A few weeks ago I swapped out my 726EL’s that were down to 5/32’s to brand new XDN2’s. At the same time I replaced the drums/brakes and recalibrated my speedometer(went from tall to low pro). I figured my 7 mpg average would lose a few tenths, no big deal but I’m struggling to get more than 6.2-6.3, and sometimes less than 6. I’m really thinking next spring of getting some straight treads and having two sets of tires. Bad mileage sucks. BTW: 726's are horrible on fuel mileage. The extra bit of tread life they have is NOT worth it. Your speedo and engine tire size settings will not effect your fuel mileage. You should always be checking your fuel mileage by way of the fuel pump and a calculator. Whenever we replaced tires and from a worn out 5/32's or so tread depth to a brand new set of the same exact tires, we loost about 0.7 mpg for the first 80k miles or so while they break in. That is a lot, so we decided we need to run our tires as long as down to minimum absolutely possible this go around. We get about 450k miles or so out of our drives so thankfully we have only had to suffer that fuel mileage hit a couple times so far. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 10-28-2018, (Subject: Tire rolling resistance (copied from another forum). ) Post: #4 | |||
RE: Tire rolling resistance (copied from another forum). (10-27-2018 )shoe128 Wrote: its not allabout the rolling resistance nubbers traction and wr aswell ... If you run light, rolling resistance does not do a lot for you. Wear should be considered along with the things you mentioned. If you run medium to heavy however, rolling resistance is absolutely everything. It trumps wear/longevity and anything else by leaps and bounds in long term operating costs. Wear is not even a consideration at all because you save so much fuel with better rolling resistance than any tires that are cheaper that "wears less", that you save as much as 10x fuel savings alone during their life over the little bit of price differences between them. If you can compare 2 low-roll tires and they are almost the same, but one "wears less", even then, it is a toss-up. The one that claims to wear less, is usually more expensive and the cost savings would likely never be seen, but who knows. - I say you can't go wrong either way, as you drives should last a long time any ways. Lastly, if someone has to worry about drive tire costs all the time, they are replacing their tires too often. - THAT should be the main focus above all else. A good set of drives that are well cared for on a highway truck should last most people a minimum of 350+k miles and 400 - 450k+ miles if you drive them right. If someone is changing tires more often that that, then there had better be a good reason (off-roads, over 80k weights, etc.), and your freight rates should reflect this too. Higher operating costs = charge more money to your customers to offset it. Just a reminder that sometimes people focus on the wrong things when other, more expensive things should be resolved first. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 10-28-2018, (Subject: Tire rolling resistance (copied from another forum). ) Post: #5 | |||
RE: Tire rolling resistance (copied from another forum). (10-28-2018 )schISM Wrote: A few weeks ago I swapped out my 726EL’s that were down to 5/32’s to brand new XDN2’s. At the same time I replaced the drums/brakes and recalibrated my speedometer(went from tall to low pro). I figured my 7 mpg average would lose a few tenths, no big deal but I’m struggling to get more than 6.2-6.3, and sometimes less than 6. I’m really thinking next spring of getting some straight treads and having two sets of tires. Bad mileage sucks.id be happy tostart with 6.3 or so asim only getting 5--5.2 2016 ih isx15 342gr 18b ya i run hard and heaveyyy but i get the same bob tail imlooking in to it a little bit at a time thats only .3--.5 more than my old89 cabover pulling up to 150th User's Signature: Just my 2 cents + - | |||
| 10-30-2018, (Subject: Tire rolling resistance (copied from another forum). ) Post: #6 | |||
| RE: Tire rolling resistance (copied from another forum). Just FYI but XDN2 have some of the worst rolling resistance michelin offers. It's the open shoulder design that causes the loss in efficiency. | |||
| 10-31-2018, (Subject: Tire rolling resistance (copied from another forum). ) Post: #7 | |||
| RE: Tire rolling resistance (copied from another forum). I have about 150k on my 726's and they are already half worn out. Lately, I do go to customers that require alot of tight turns and half of my driving miles are city. My dedicated route is only 75 miles a day for all miles, I do occasionally run overweight isotanks to a plant 45 miles away for extra money if I have the time...I average 800 miles a week if I use at least 62 hours of my 70. Because my inners are rusty steel and I have curb rash from a previous asshole on my steers, I'll be replacing my springs, bushings, upgrading to better shocks and replacing my wheels before I put on a new set of 710's. Im even changing my aging steering box and tierods, etc because of it before it goes (768k on it now) I'm not impressed with the 726's...I would scrub off speed on a slight decline at 85k gross. That is HORRIBLE rolling resistance, not to mention it's an aerodynamic brick. I will be keeping in mind what rawze said, and I agree, your profit must reflect that level of wear and tear...I get paid very well now as a local driver, and since I run near and slow, my maintenance cost dropped an average of 70% while my gross jumped 25%. I have no reason to complain, the truck is paid for, and in the next few months, it'll be getting the works to keep those profits coming in. User's Signature: 2010 T2000, CM871, 13spd, 1.173m, tanker yanker Overhauled @ 927k | |||
| 11-01-2018, (Subject: Tire rolling resistance (copied from another forum). ) Post: #8 | |||
| RE: Tire rolling resistance (copied from another forum). I'd like to know the RR numbers for my steering tires, Bridgestone M854's size 385/65R22.5's. I know it's a gross number, but I weigh almost 15,000lbs bobtail on the front end I run Michelin XDS2's on the drives, RR 142. But for me traction trumps RR on my drives, and won't even discuss a different tire. When I went to these from the factory BS something or others grippers, I went through stuff I knew I'd be chaining up with most anything else. That to me is worth any fuel economy price paid on the drives. Chains suck, and I have to do it more often than I like because of what I do, any reason not to is more than enough not to. Kinda surprised, I run BS R197's on my jeep and booster, and they are RR 95 (R195F was the predecessor to the R197, so that's the number I looked at). I run the R197's because of their sidewall payload rating, I do get looked at for that, and they also just run cool and wear smooth. I don't see the retread number that I run on the main trailer, it is a Bandag SST tread, and I cap my own casings. They wear like steel. I tried several different trailer tires and couldn't keep them from pulling the edges off of anything virgin. A buddy was running these and told me he cant believe how well they wore, so I tried a set. I only run them to ~40% tread depth and yank 'em. Even at that I get twice the life of any virgin I tried, and at roughly 56% the cost of the cheapest virgin, and under half of high end ones. I hate them, but they work. They require attention/inspection to make sure the cap isn't separating, but at 20k an axle all tires need attention. I've never blown a cap because it was a cap. I've blown a couple, but they came apart at flat repair points, I've had virgins do the same, so I don't count that. Weight takes its toll. I've had 2 separate in over 6 years, caught both and got warranty on both. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
