|  cm870 crankcase breather  |
|  08-14-2017, (Subject: cm870 crankcase breather )  Post: #1 | |||
| cm870 crankcase breather  Does Cummins make a maintenance free filter for the 870? I was reading the thread about it and all they talk about is for the 871.  | |||
|  08-14-2017, (Subject: cm870 crankcase breather )  Post: #2 | |||
| RE: cm870 crankcase breather  I believe it is the same one. Maybe call a dealer to double check.  | |||
|  08-14-2017, (Subject: cm870 crankcase breather )  Post: #3 | |||
| RE: cm870 crankcase breather  They can't do anything without a part #....... I googled it and came up with CV50638 as an original replacement.Anyone know if that's correct?  | |||
|  08-14-2017, (Subject: cm870 crankcase breather )  Post: #4 | |||
| RE: cm870 crankcase breather  870 doesn't have a crankcase filter. Those started in 2007 with the DPF and 871. 870 vents to the ground.  | |||
|  08-14-2017, (Subject: cm870 crankcase breather )  Post: #5 | |||
| RE: cm870 crankcase breather  I had an 870, I swear it had a CC filter on it. Maybe I'm thinking of something else then.  | |||
|  08-14-2017, (Subject: cm870 crankcase breather )  Post: #6 | |||
| RE: cm870 crankcase breather  Mine doesn't anyways, Its vented to the ground.  | |||
