Camshaft and Crankshaft Speed/Position Sensor 871 |
09-23-2017, (Subject: Camshaft and Crankshaft Speed/Position Sensor 871 ) Post: #1 | |||
Camshaft and Crankshaft Speed/Position Sensor 871 Question, the Crankshaft and Camshaft Positioning/Speed Sensors, are they the same part on the CM-871? I am looking to replace the Crankshaft sensor down by the damper. I had no luck finding any sensors on Quickserve and called the dealer. My parts guy was surprised when he pulled up the part and said it was the same sensor for both applications? He gave me part number 4921599. Is this correct regarding this sensor being used in both locations? Thanks! | |||
09-23-2017, (Subject: Camshaft and Crankshaft Speed/Position Sensor 871 ) Post: #2 | |||
RE: Camshaft and Crankshaft Speed/Position Sensor 871 I don't know the part numbers Waterloo, but yes the crank sensor is down by the damper. Diagrams: Quickserve->Service->Electronic Control Systems Troubleshooting and Repair Manual->Section E Engine and System Idnetification->(16-100-002)Engine Diagrams 14-Engine speed/position sensor User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
09-23-2017, (Subject: Camshaft and Crankshaft Speed/Position Sensor 871 ) Post: #3 | |||
RE: Camshaft and Crankshaft Speed/Position Sensor 871 5-Camshaft speed sensor User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
09-23-2017, (Subject: Camshaft and Crankshaft Speed/Position Sensor 871 ) Post: #4 | |||
RE: Camshaft and Crankshaft Speed/Position Sensor 871 (09-23-2017 )Waterloo Wrote: Question, the Crankshaft and Camshaft Positioning/Speed Sensors, are they the same part on the CM-871? I am looking to replace the Crankshaft sensor down by the damper. I had no luck finding any sensors on Quickserve and called the dealer. My parts guy was surprised when he pulled up the part and said it was the same sensor for both applications? He gave me part number 4921599. Is this correct regarding this sensor being used in both locations? Thanks! I always have trouble finding sensor part numbers on QS, but YES, they are the same. Number 31, says (2) cam or crank Thanks for giving me something to do, I'm getting bored waiting for the canoe... User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
09-24-2017, (Subject: Camshaft and Crankshaft Speed/Position Sensor 871 ) Post: #5 | |||
RE: Camshaft and Crankshaft Speed/Position Sensor 871 Thank you sir! I replaced the sensor up at the head, #5 and figured it would have been better to replace both. You know the old saying, when one of two goes, replace both, as the other is soon to fail. | |||
