Here’s where I am at, what would you guys do?
11-13-2017, (Subject: Here’s where I am at, what would you guys do? )
RE: Here’s where I am at, what would you guys do?
(11-13-2017 )Hammerhead Wrote:
(11-13-2017 )Starlight Wrote:
(11-13-2017 )JMBT Wrote:  Thanks for the input guys!! I figured you would all agree to change it, so I ordered the tool earlier today. It will be here Tuesday. I have the seal, dampner, crank sensor, a fan clutch rebuild kit, fan hub bearings, both belts, tensioners, and the AC idler pulley, all setting here in front of me ready to go!
Can any who have done the front main seal tell me what kind of grease they use on the new seal for installation???
Thanks
Both front and rear crank seals install dry, don't use any lubricant on it. Be sure to have the surfaces in the front structure and the crankshaft clean before installing seal and you'll be fine.
Hey, he's back!
I was up in FSJ a couple of times and tried calling you, but the number you PM'd me wasn't yours anymore...
My bad, number still the same, sent you pm.
