INSITE
04-12-2016, (Subject: INSITE )
Post: #19
RE: INSITE
(04-08-2016 )Jerzy609 Wrote:  I need some help with this Insite. I ordered Insite 7.62 off of eBay and it arrived at my house about 10 days before I got home. I remember that I was supposed to send my pc-id back to the seller but I haven't been contacted back and eBay says the sellers store is closed because of difficulties. Idk know if I should just try to send it back and try to get reimbursed either thru the seller or eBay or if somebody can help me out with this.
Thanks Curt
I had the same the issue until I bought insite fix software. If u can give me your picd I'll help you. Just sent me an pm.
04-13-2016, (Subject: INSITE )
Post: #20
RE: INSITE
(04-12-2016 )jesse20 Wrote:
(04-12-2016 )snailexpress Wrote:  Ebay
does anyone have the new 8.1 version of insite? on the inside page it appears i can just download it but how much would the license cost me?:s
$600
06-18-2016, (Subject: INSITE )
Post: #21
RE: INSITE
Lady told me it was $436, or close to it for the fleet version. Supposed to do everything but load calibrations.
08-20-2016, (Subject: INSITE )
Post: #22
RE: INSITE
I got my inline 6 all installed, just need the {**Content removed by protection bot**- filesharing.}. Can some one PM me options that may exist?
User's Signature: I don't know sh!t from shinola!
06-11-2017, (Subject: INSITE )
Post: #23
RE: INSITE
Hi everyone! Which one inline 5 or 6 you would recommend to buy and use for CM871 2009 with software insite 7.6.2. Or your suggestions. Thanks!
Post: #24
RE: INSITE
Either of those will be fine if you just plan on using Insite. If you plan on using software for OEM modules, ABS, gearboxes, etc then consider a Nexiq adapter.
 Thanks given by: Vlad
Post: #25
RE: INSITE
Thanks Signature620!
10-09-2018, (Subject: INSITE )
Post: #26
RE: INSITE
Can someone possibly help me out with the insite software as well? I have a 2012 cascadia with a cm2250, thank you in advance
Post: #27
RE: INSITE
What exactly do you need help with?
