| What gear oil |
| 03-03-2018, (Subject: What gear oil ) Post: #1 | |||
| What gear oil What gear oil do I add at pm for a cm870. Thank you | |||
| 03-03-2018, (Subject: What gear oil ) Post: #2 | |||
| RE: What gear oil 80 90 gl 5 is what I use. Probably shouldn’t use gl5 but that’s what Walmart has. I think new gl 5 doesn’t eat brass. | |||
| 03-03-2018, (Subject: What gear oil ) Post: #3 | |||
| RE: What gear oil Sta-Lube SL24239 API/GL-4 Multi-Purpose Hypoid Gear Oil - 1 gal https://www.amazon.com/dp/B000M8RYMC?ref=yo_pop_ma_swf This is what I use in my CM870 a gallon every 10 thousand miles. | |||
| 03-04-2018, (Subject: What gear oil ) Post: #4 | |||
RE: What gear oil (03-03-2018 )MBlazevic Wrote: Sta-Lube SL24239 API/GL-4 Multi-Purpose Hypoid Gear Oil - 1 gal https://www.amazon.com/dp/B000M8RYMC?ref=yo_pop_ma_swf this is also what I use. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 03-05-2018, (Subject: What gear oil ) Post: #5 | |||
| RE: What gear oil I used the walmart 80 90 gl5 for last couple hundred k miles, I need to check with mr.hagg on how the engine internals look he is doing the inframe now | |||
| 03-05-2018, (Subject: What gear oil ) Post: #6 | |||
| RE: What gear oil I’ve been kinda wondering on this gl 5. Feed back would be cool. | |||
| 03-05-2018, (Subject: What gear oil ) Post: #7 | |||
| RE: What gear oil Magard look inder Rawze technical documents. Why I add 12% (one gallon) of gear lube at every oil change... Read on brother, it'll have more than enough info for you to make an informed decision. | |||
| 03-05-2018, (Subject: What gear oil ) Post: #8 | |||
| RE: What gear oil I’m running a gallon of gear oil. It’s gl 5 because it hard to find gl 4. I’m wondering what the friction modifiers do in the oil. There made to not be too slippery for the limited slip clutches in a reared. | |||
| 03-08-2018, (Subject: What gear oil ) Post: #9 | |||
| RE: What gear oil OK, dumb question... Supertech GL5 at Walmart for $13 a gal or the Sta-lube GL4 at Amazon for $39. Is the GL4 that much better? | |||
