Turbo
04-03-2018, (Subject: Turbo )
Turbo
Will a turbo from a 2350 work on an 871
RE: Turbo
871 turbo is a good bit bigger to provide more air to the lower compression engine.
RE: Turbo
If im not mistaken unilevers put a 871 turbo on a 2250 or 2350 engine.
RE: Turbo
(04-03-2018 )Pirate31red Wrote:  Will a turbo from a 2350 work on an 871
that would heavily depend on your goals and expected outcome.
RE: Turbo
actually i have done it. its weird and i wouldnt suggest it but i did do one 871 i put a 2350 turbo on it because the guy just happened to have it.
Putting a 871 turbo on a 2350 ive done lots of.
uni
RE: Turbo
I only want to do it because I have one already I do have another correct turbo for the 871 but it leaks oil into the compressor side
RE: Turbo
(04-03-2018 )Unilevers Wrote:  actually i have done it. its weird and i wouldnt suggest it but i did do one 871 i put a 2350 turbo on it because the guy just happened to have it.
uni
Are the 871 and 2250/2350 turbo mounting flange the same?
Or does the exhaust manifold need to be changed as well?
RE: Turbo
uni
871 has bigger studs - there was some drilling done and custom work to accommodate it.
 Thanks given by: Hammerhead
04-04-2018, (Subject: Turbo )
RE: Turbo
Unilevers, what was the reasoning behind it? Just curious.
