fault codes 08 IHC
07-01-2018, (Subject: fault codes 08 IHC )
fault codes 08 IHC
is there place on internet can look up faultcodes 2008 IHC ,9200i,cm871, have code 128FO7,136FO7, SID146-P, get one thing working (AC) sumthing else pops up, reminds me of snowmobiles in the 1970s
User's Signature: willies way
RE: fault codes 08 IHC
I usually google search the code number. But im fairly sure the 128f is an engine fault and 136f is ABS fault which are 2 different systems. So im not sure why they're on the same code line and the "p" is for previously active or inactive code.
(07-01-2018 )terrycrockett Wrote:  is there place on internet can look up faultcodes 2008 IHC ,9200i,cm871, have code 128FO7,136FO7, SID146-P, get one thing working (AC) sumthing else pops up, reminds me of snowmobiles in the 1970s
Yes, quickserve.cummins.com
ok thanks
