2013 Freightliner Cascadia w 2250 cummins
08-14-2018, (Subject: 2013 Freightliner Cascadia w 2250 cummins )
My truck has no power to it it lags but it does pull the loads a week ago I had my clutch replaced in it. The fuel pump I do not believe has been updated and I will get that done and I wonder if that may help increase my pulling power? Also planning on changing my IMAP sensor, Delta P sensor, and those other sensors with it as well as cleaning my EGR. Yeah this fuel mileage is killing me only 5 to 6 .30 MPGs besides my driving habits I know there's something going on. Has anyone dealt with this before? What did you do to fix it?
08-15-2018, (Subject: 2013 Freightliner Cascadia w 2250 cummins )
RE: 2013 Freightliner Cascadia w 2250 cummins
How many miles on the truck? Any codes?
Has 513k, nothing on the engine light, haven't scanned it.
08-17-2018, (Subject: 2013 Freightliner Cascadia w 2250 cummins )
Put the computer on it and see if there are any codes, could be a number of things.
... and get the guts of that fuel pump replaced asap to prevent the lurking total engine destruction you are gambling blindly with there.
No, it is not going to make more power when you do this.
08-18-2018, (Subject: 2013 Freightliner Cascadia w 2250 cummins )
(08-17-2018 )Rawze Wrote:  ... and get the guts of that fuel pump replaced asap to prevent the lurking total engine destruction you are gambling blindly with there.
Ok, I'm delivering in Waycross Monday, I got the some sensors, delta p, and imap. I put on a new air filter. I'm going to go to that shop after and get my fuel pump fixed. She knows what the parts are bc there apparently isn't a little for it. She said I could do it myself in 2.5 hours. So I'm going to go up there and see what I have to do. If your not doing anything that day or have some free time I wouldn't mind getting an opinion about what I should also do to it. Thx
08-19-2018, (Subject: 2013 Freightliner Cascadia w 2250 cummins )
(08-18-2018 )flatbed94kid Wrote:  Ok, I'm delivering in Waycross Monday, I got the some sensors, delta p, and imap. I put on a new air filter. I'm going to go to that shop after and get my fuel pump fixed. She knows what the parts are bc there apparently isn't a little for it. She said I could do it myself in 2.5 hours. So I'm going to go up there and see what I have to do. If your not doing anything that day or have some free time I wouldn't mind getting an opinion about what I should also do to it. Thx
Let me know if you end up over at Mr. Hags. I could possibly show up over there and say hi. I PM'd you my number.
09-01-2018, (Subject: 2013 Freightliner Cascadia w 2250 cummins )
Well, flatbed94kid showed up over here on the 24'th. I made mention of what we did on the bottom half of this post...
http://rawze.com/forums/showthread.php?t...4#pid29704
09-02-2018, (Subject: 2013 Freightliner Cascadia w 2250 cummins )
Thankyou Rawze
